Thread: Hardwiring iPhone charger
    Regular Member pogvec's Avatar
    Nov 2011
    Uk
    Default Hardwiring iPhone charger
    Has anyone hardwired a iPhone charger into there car?
    I'm thinking about doing this with one if these http://www.ebay.co.uk/itm/CAR-CHARGE...#ht_1215wt_922 and cutting the plug off and wiring it to the back of the fag lighter
    Regular Member John Bishop's Avatar
    Oct 2010
    Why not just use this, saves the hassle, it's what I use.
    http://www.ebay.co.uk/itm/3-IN1-USB-...01733588195772
    Nov 2011
    Uk
    That's what ive got at the minute but i want it wired I out the way!
    Full Member
    South West
    Could do what i have done... Buy a 2 way cigarette lighter splitter, cut the end off which goes into the cigarette lighter, take a feed off the live which powers the passengers cigarette lighter and run the splitter into the arm rest. Then in the center cup holder, cut a hole big enough to get the iphone lead through and again in the bottom of the center arm rest and plug the iphone lead into the cigarette 2 way splitter. With a bit of modification to the cup holder you can get your iphone to sit flush inside it with the charging connecter just having to be plugged in. I'll get some pics and upload when i can to give you some idea. Its a 1/2 hour job and totally invisible. Been using it for a year or so now and it works a treat.
    Nov 2009
    manchester
    I bought the usb cig charger and with my dremel thinned out the top bit, so the whole things fit flush inside the cig lighter, and with the cover closed you cant see it
    Oct 2010
    Pogvec. If you need the car charger drop me a line and I will send you one, save you buying it.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    If it was me, I'd wire up one of these to save the hassle......................
    https://www.roadpro.co.uk/retail/pro...Socket&id=1044
    https://www.roadpro.co.uk/retail/pro...+Panel&id=1045
    Besides if you decide to change phones at some point then you may be lucky as quite a few phones nowadays charge via USB (Including if your mate need to charge their phone on a journey)
    Hope that helps
    Damo
  1. Nokia DC-9 Car Charger
    By Lump in forum General items for sale
    Last Post: 9th January 2010, 17:31
  2. Which battery charger?
    By Endlessdeep in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2009, 11:33
  3. Hardwiring GPS using miniUSB?
    By In a states in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2006, 22:13
