Thread: Air con blowing cold
    derbyshire
    Default Air con blowing cold
    Hi there folks. Just trying to find out if anyone as had a problem with there air con blowing warm. I have a 2004 signum elite T with climate control and up to now the air con as been blowing cold. For some reason it will only blow warm at the moment. Havnt done anything to the car other than having it valeted which produced rather a lot of condensation.
    Thanks malc
    Regular Member John Bishop's Avatar
    Oct 2010
    You not getting any heat out at all? Especially the centre vents
    May 2006
    scotland
    Maybe the flaps are stuck in the 'hot' position. Can you override the CC and adjust the heat setting manually just like a car without CC? If you can, do you hear any electric motors whirring away in the dash area when you change the heater control from cold/hot, hot/cold?
    derbyshire
    Hi . I get plenty of heat out of the heater through all the vents and all the speeds work on the motor, i replacer the resister about 12 mths ago, it just wont blow cold
    May 2006
    Mansfield
    Apologies if you have already checked this, but is the air conditioning actually on ?. (check in the Climate control menu)
    All the best
    SJ
    Regular Member krazylegz's Avatar
    South Shields
    It may need regassing mate
    Sent from my iPhone using my fingers n thumbs
  1. Aircon not blowing cold
    By Ralphwells1967 in forum Troubleshooting
    Last Post: 14th September 2011, 22:38
  2. Vectra LS blowing cold air only
    By andy64 in forum Troubleshooting
    Last Post: 23rd January 2011, 18:04
  3. Heater only blowing cold air
    By Chilie in forum Troubleshooting
    Last Post: 23rd December 2009, 18:26
  4. Vectra C blowing cold air
    By 999bruno in forum Engine & Drivetrain
    Last Post: 19th December 2009, 12:40
  5. Heater blowing cold.
    By neilgsi in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2008, 17:48
