Thread: Boot saga continues
    kent
    confused Boot saga continues
    Hi all, my boot on the vectra can only be opened by key, if i use the fob the indicators flash and number plate light comes on but no boot motor noise. the door switch for the boot beeps but again nothing opening boot wise someone suggested opening the boot and removing the grommet near the latch and putting a screwdriver in the hole to reset the motor...trouble is there is no grommet or hole!!! have also tried having the key hole vertical and horizontal and then using the fob...guess what..nothing ( sorry to bore you all with this again, but is a real pain in the ass sometimes!!
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    have you checked the fuses in the fuse box ????
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Quote Originally Posted by MARK RC View Post
    Mine does just this but I don't have a key at the rear just a button but when the unlock is activated I press the button and it opens, unless I am missing something and you have electric opening tailgate as on the estate it appears to be doing the right thing as its not supposed to open the boot or activate the release motor until you press the button on the boot lid.
    May 2012
    UK
    Quote Originally Posted by wardy23 View Post
    Wardy,
    what is the fuse number and where is it located?
    Jun 2012
    manchester
    Vehicle : Vectra C estate
    Engine : 3.0 V6 CDTI
    Mileage : 126000
    i had the same problem, however i found that the button on the door handle is just to unlock the boot as it tends to lock after a certain time(someone please correct me if im wrong), the key fob also just unlocks the boot. I dont have an auto openning tailgate.
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Spray some WD 40 into the lock through the key slot then give the button a good hard and fast push (as much as your thumb can stand lol) mine does this now and again it just seems to get sticky
    Regular Member Munkey's Avatar
    Jun 2012
    United Kingdom
    Not sure if it helps, but I had an E39 5 series that did this & the plastic connector that unlocked using the motor (triggered by pressing the remote) for release had broken. The key worked using a separate metal bar to release the latch.
    Went to the scrappy & just replaced the motor and silly plastic connector.
  1. And the saga continues....
    By dunkymunky in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2012, 18:26
  2. VXR Exhaust Saga Continues
    Last Post: 18th February 2010, 12:10
  3. The nightmare continues.
    By RJPITCH in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2007, 10:59
  4. The nightmare continues....
    By vectravirg in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2007, 19:55
  5. The curse continues
    By DennisTheMenace in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2007, 23:31
