Thread: cuttin lighting loom advice req
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default cuttin lighting loom advice req
    i need to fit a new plug on the headlight so i will need to cut the loom and solder a new bit in. will i be ok or should i disconnect the battery firstthanks mrk
    Engine : 1.9 CDTi
    If the lights are off and the ignition is off you will be fine.
    Trim : improving
    Year : 06
    just wasnt sure about bulb check circuit etc with canbus system
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    38 Post(s)
    Engine : 1.9 DTH
    U could de pin them too as it was done to my car no need to cut it
  1. Advice on parrot wiring loom please :-)
    By ridgers84 in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2012, 20:42
  2. Quadlock Extension Loom or ISO2Car loom
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2010, 15:59
  3. Lighting
    By John LE in forum Part Numbers
    Last Post: 15th March 2010, 02:33
  4. Loom and mirror fitted but advice needed
    By collow123 in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2009, 22:13
  5. Rubbish basic Loom to higher spec loom?
    By redraptor_141 in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2009, 21:58
