Results 1 to 10 of 11
Thread: Help!!!!
    May 2012
    BIRMINGHAM
    confused Help!!!!
    Hi there i am new to the forum,
    Well the other day, i disconnected the battery to reset the ECU.....but i disconnected and reconnected the live and not the earth, which i have since realized is the wrong thing to do!!!!
    Well now my battery is dead and i just get the clicking when i try to start the car, i had the RAC out who jump started the car and said that my battery was fried, the battery has stopped holding the charge, I'm guessing i did that?
    Anyway just wanted to know is that all i did as it seemed the car ticked over fine when the RAC man started it, everything electrical worked and he said the alternator was blasting out enough to charge the battery but it just wasn't holding it, so i have fried the battery? Could i have knocked out a fuse that is stopping the battery from charging?
    By the way my car is a 2004 1.9CDTI vec............advice please??
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    try putting the battery on charge and see what happens
    May 2012
    BIRMINGHAM
    Quote Originally Posted by wardy23 View Post
    Tried 3 hours charge mate, still get the clicking?
    11 Post(s)
    A dead battery will take longer than 3 hours to charge (unless on a boost pack)
    ps, putting "help" as a subject header is about as vague title as you can get. Try to give people a clue to as what the question is - might get you more visits from people who could assist.
    May 2012
    BIRMINGHAM
    Fair comment so that's why nobody has responded!!
    I will grab my brothers charger and charge it over night, should i take the battery out of the car?
    Also with my ****in the connections up is the battery ******ed before i leave it over night?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Why did you want to reset ecu?
    What battery reading are you getting?
    May 2012
    BIRMINGHAM
    Quote Originally Posted by Critch View Post
    Cuz i thought it would get rid of the fault codes that showed up when the RAC bloke ran the diagnostic machine on it, i don't know what the reading off the battery was cuz it was a few days ago now but the RAC man told me it wouldn't hold a charge even if i dragged it a couple of junctions down the M5, but that means nothing to me as they said the same last time my battery went pear shaped on a 407 i had and i drove it around for an hour or so and hey presto it started in the morning.
    This time though i aint so sure as like i said i only disconnected the live wire so i may have fried it?
    May 2012
    BIRMINGHAM
    Battery was fried oh yeah.........new one purchased
    Dec 2011
    Seaham
    It doesnt matter which side you disconnect as there will be no circuit?
    Maybe your problems were with a failing battery??
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by Ben50n View Post
    Agreed - I have disconnected batteries both ways with no issues.
    Your battery was probably on it's last legs anyway. If it was dipping below the minimum voltage required to run some circuits, then sometimes the CANbus communication is affected, and spurious fault codes pop up from all over the place.
    Regarding fault codes... If the spanner symbol ain't staying on more than a few seconds after start-up, and it ain't coming on whilst you are driving, then I would not worry about the codes.
    Mine has had a fault logged since the day it left the factory 7 years ago... no amount of clearing the DTC (Diagnostic Trouble Codes) will sort it... the car runs perfect by the way.
    If the car runs fine, and the spanner light is not on whilst you are driving, then just chill out as there is no problem to worry about.
