Results 1 to 10 of 15
Thread: For those of you with sun blinds
    Regular Member Carl83's Avatar
    May 2011
    Basingstoke, Hampshire
    Default For those of you with sun blinds
    Hi guys,
    This is a question for those of you with sun blinds. How do you have the rear blinds fitted?
    I have mind overlapping in the middle, which is the only way I could get them to fit. I did try butting them up to each other, but then they bulged in the middle. I try and have a thin line down the middle so its not too much of a distraction in the mirror.
    I do like the blinds, they are a good cheap alternative to having your windows tinted, but the blinds for the back window could connect better. If one of them had some clips that the other clipped into, it would have been so much better.
    Your comments are appreciated.
    Carl
    Sent from my Samsung Galaxy SII using Forum Runner
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Hi carl, I had same problem, they do however bend into shape quite nicely, and they shouldn't overlap.
    with some fiddling you will get them perfect, just takes a while tho.............hth
    Andy
    Mine fit without the need to overlap, push them well into each side.
    Worth checking to see if your trim is a little off set although I doubt it hth .....................
    May 2011
    Thanks guys, wasn't aware they weren't meant to overlap. The benefit of them overlapping is that the join is thinner.
    I will take a picture of the current join.
    I will give it ago with fitting them properly.
    Carl
    Regular Member simmo3187's Avatar
    Jul 2010
    North Wales/North West Border
    Engine : 3.0 V6 CDTI
    Where did you get them from mate
    May 2011
    Ebay, they were £90-100 in total.
    Carl
    Jul 2010
    oh lol....i sold mine on ebay last week for £50 to a lad called Carl and thought it might have been you thats all
    Jan 2012
    Somerset
    My rears don't overlap and fit quite nicely. Took a little fiddling but no hassle
    May 2011
    Well I have just gone and had a play with my blinds and still can't get them to fit how they should. They still bulge in the middle.
    I don't think I have the patience to keep trying.
    Carl
    kirriemuir
    mine overlap as well thought they were suppose to also
  1. Blinds
    By Keithy in forum Styling
    Last Post: 20th October 2010, 06:47
  2. Uv blinds
    By yadziyad in forum Styling
    Last Post: 17th January 2010, 19:23
  3. rear blinds
    By willoftoon in forum Styling
    Last Post: 27th June 2009, 20:44
