Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: This mornings job: CDTI 150 Timing belt kit and water pump, with Pics :)
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default This mornings job: CDTI 150 Timing belt kit and water pump, with Pics :)
    As above..
    Wasnt happy that I didnt know 100% the history of the current belt etc on my car - so popped to VX this morning and all the bits were in stock and I set too it replacing the full timing kit and water pump.
    Reasonably simple job to be honest..
    Few things you need to remember - like the various tools you will need from E sockets to T sockets etc.. Plus a bit of silicon sealant
    Haynes will tell you all the torque settings - thats about all its good for really
    Some Pics for you:
    All exposed:
    Timing Marks lined up - forgot to take one of the cam pully - but you will see that below on fitment of new belt:
    Tensioner before I touched it:
    Old bits out
    New bits fitted and Timing marks confirmed:
    You can see from the above that using a Genuine belt the belt has timing markers - so you cant lose the timing of the car.. make sure all your markings line up before you remove the old belt - fit the new one and line the yellow lines with the timing marks and you cant go wrong
    All fitted with new belt, tensioner, pully and pump!.
    IMPORTANT: When you remove the water pump.. you MUST clean up the old bolts with a wire brush etc. to get all the old sealant off.. then apply silicon sealant to the threads of the bolts. Work it into the thread with your fingers - not too much, but enough to 'seal' the thread.. this is important as the bolt holes are in the coolant stream..
    use the correct Torque settings on all bolts...
    Job Done!
    A
    Regular Member hairytimes's Avatar
    Apr 2012
    norwich
    nice do for it
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by hairytimes View Post
    nice do for it
    Middlesex
    Trim : SRI
    Mileage : 100k
    Glad I did do it too as the belt wasnt a GM belt - although it was a gates belt - and the pully and pump were something different too.. Suspect that the last time the belt was done it was only the belt and everything else remained.
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Mileage : 140000
    superb job ant, well i guess i know who to ask when i need mine doing
    (And considering it was the same garage that did my thermostat it might be sooner rather than later)
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by CH-VECTRA-ELITE View Post
    - not a problem
    All in I think it took me about 3 hrs - and I was taking my time etc. so not really a bad job.. Thats with getting tools out and in too
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    good effort! I intend to do my belt at 50k so glad to know its not to much of a pain, what's it like setting the tensioner?
    Did you have a look at my video first too...?
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by Penfold101 View Post
    Oh I didnt mate - sorry ....
    Middlesex
    Trim : SRI
    Mileage : 100k
    Looked up the Vid - top notch!
  1. Replies: 29
    Last Post: 25th July 2012, 22:52
  2. Timing belt kit and water pump
    Last Post: 21st May 2012, 20:17
  3. timing belt and water pump
    By Garfo in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2011, 21:08
  4. CDTi 150 Timing belt & water pump
    By RobW in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2010, 16:00
  5. Timing belt and water pump done
    By DavieVectd120 in forum Engine & Drivetrain
    Last Post: 1st April 2010, 19:03
