Thread: Parking light bulb warning keeps coming on and off
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Parking light bulb warning keeps coming on and off
    I keep getting a warning on the dash saying the parking light bulb has gone. Thenn after a little while it will go off.
    I had a look at the bulb and it looked a bit dull when on so gave it a wiggle and it went brighter.
    Is it common to have to replace the bulb holder on the estates?
    Seen this on ebay so might see what happens: http://www.ebay.co.uk/itm/2509239602...=p5197.c0.m619
    £5.50 seems a tad expensive for such a small part.
    Jul 2009
    Brighton
    you can carefully prise the contact spring to ensure a better contact, also some contact cleaner, or just scratch it with a small screwdriver.
    Maybe the bulb is on the way out!
    Jun 2006
    North West
    Update: It turns out its not the rear bulb that its complaining about but the drivers front sidelight. It keeps going off. Then it'll be ok for a few days then it will start switching on/off. I have just had the front drivers headlamp unit replaced as the old one kept filling with water.
    I am hoping it's just the connector is not on tight (from when it was replaced) or the bulbs are on their way out.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    Ref the bulb warning. Double check that all the rear lights are lit in the same places - as the vec will use another bulb in a slightly different area for the rear brake and tail lights should one fail.
  1. Front offside parking light bulb.
    By pilgrim in forum Electrical & ICE (including SatNav)
    Last Post: 21st February 2013, 10:38
  2. Bulb warning light.
    By telstar in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2011, 20:43
  3. Seatbelt warning light/chimes keep coming on...
    By mr-s in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd September 2009, 16:34
  4. Parking light check bulb light on and wont go off
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2008, 12:03
  5. Rear left parking bulb warning
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2007, 12:37
vectra sri parking light warning
parking light keeps coming on vectra c
