Results 1 to 10 of 15
Thread: Display Safe??
    May 2012
    cheshire
    Default Display Safe??
    Hey ive managed to get stereo on!!
    But now it says display safe ?
    How do i get to put code in ?
    Many thanks
    Full Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Switch ignition on
    Make sure Headunit is switched off
    Press "AS", keep pressed and switch on stereo
    You will here a bleep, and the display requests the code
    Use radio presets 1 to 4 to input code pressing each preset as many times as the digit in the code
    Press "AS" again, keep pressed until unit is functional.
    Admin plasma's Avatar
    On the Forum
    216 Post(s)
    Engine : 150
    Mileage : 74000
    1.9cdti would probably be full canbus, if so and its a cd30/cd70/cdc40 then the screen needs to be programmed to the radio via the car security pass. Its making me wonder why its doing that in the first place though.....
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    May 2012
    cheshire
    Ive got the stereo working now!!
    But still have display safe on screen?
    The time clock he set its self.
    Will this display change on its own ?
    Many thanks
    On the Forum
    216 Post(s)
    Engine : 150
    Mileage : 74000
    have you read any of what i typed above?
    May 2012
    cheshire
    Sorry just seen it now,
    How do i get these passed?
    On the Forum
    216 Post(s)
    Engine : 150
    Mileage : 74000
    first off, whats the circumstances which has led to the problems your having with the radio and display?
    Full Member Robsey's Avatar
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    I can answer this one, as I answered his previous thread..
    Okay you got the Vectra, which was fitted with a display and a Sony Xplod head-unit.
    You removed the Xplod head-unit, and bought a replacement CD30
    Now then - if either the display or the head-unit are in divorced state, then you will get an intermittent pop-up message saying display safe.
    If they are both paired, but not to each other, then the message will stay on all the time.
    Now then - from what I understand, you have fitted a CD30, but not the matched display.
    What you need to do, is pair the display and the CD30 using Tech 2 or Vaux-com.
    I am guessing that the display is your car's original unit that it left the factory with.
    If that is the case, then the Audio pass should be in your owner's pack - a red cardboard credit card thing.
    On there will be a 4 digit security code.
    I am guessing that you need to get your dealer or someone equipped with the devices that I mentioned above, to pair your new cd30 to the exisiting display using the security code described.
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    You didn't mention if the pop-up message is popping up every 5 seconds, or if it is on all the time.
    If it is on all the time, then you need to get the original security code for the CD30.
    Without this, you will not be able to reset it to divorced or factory state.
    You will need to have the CD30 divorced, before it can be married / paired to the display.
    If the message is popping up every 5 seconds, then the head-unit is already divorced, and you simply need to get it paired to the display.
    May 2012
    cheshire
    Hi the display safe pops up about 15 secs after the stereo is on.
    I have the stereo code
    when i get in the car the stereo displays on the dash screen for 15 secs then switches to display safe
    do i still need a specialist?
    thanks
  1. display safe
    By khile in forum Electrical & ICE (including SatNav)
    Last Post: 10th May 2012, 23:46
  2. Display safe
    By ServerKing in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2010, 06:05
  3. Display Safe...?
    By n_hudson in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2009, 13:57
  4. display safe !!??
    By bravocorsa in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2008, 15:10
  5. SAFE on display
    By D-S-Dave in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2007, 11:24
CC20 display SAFE
vectra c display safe
display safe vectra c
