Thread: Locking Fuel flap
    Regular Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    Default Locking Fuel flap
    Hi guys simple really should my fuel flap lock when the car gets locked? As it doesnt
    Regular Member John Bishop's Avatar
    Oct 2010
    Open your fuel flap and there should be a little hole/bracket on the inside on the left hand side. If there is then it should lock automatically.
    Dec 2011
    teesside
    Like bishbang said, if there is you need to get your hand in behind the panel in the boot and push the bar on the motor to get the pin out put a bit of oil on it and push and pull the bar on the motor a few times and it should start working, had to do it on my old vectra b.
    May 2007
    Norwich
    Engine : 2.2 z22se
    It sounds like its locking but doesnt.
    Dec 2011
    teesside
    If what I said doesnt work u will need a new one..
    You should be able to see the pin when you have the flap open, and operate the lock option
    As above, if it is powering but not moving it may have jammed
    Once this happens they don't usually last more than a few weeks, so will need replacing
    From memory access is very poor but is easy enough with a mini socket set
    May 2007
    Norwich
    Engine : 2.2 z22se
    Ok cheers guys
  1. Fuel Filler Flap Locking Motor
    By jimmy495 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th September 2011, 22:34
  2. Fuel Flap locking mechanism broken? Help please
    By luke4487 in forum Bodywork & Interior
    Last Post: 26th June 2011, 16:35
  3. Fuel Flap Locking Solenoid
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2011, 09:21
  4. Fuel flap central locking motor failed!
    By Taffyopel in forum Electrical & ICE (including SatNav)
    Last Post: 30th September 2009, 15:17
