Results 1 to 3 of 3
Thread: engine FAN problems 1.9 (120hp)
    Regular Member vectrawhite's Avatar
    Sep 2010
    Belgium (zemst)
    Question engine FAN problems 1.9 (120hp)
    Today when i was driving my car here in belgium at 24°C outside with Aicronditioning on ,I had a problem with the temp of my engine, it was arround the 100°C . After trouble shooting with opcom te system sais: RELAY FAN 3 TO LOW VOLTAGE... after testing the outputs : FAN 1 --> the 2 fan's are running slowly. FAN 2 --> the 2 fan's are running faster . FAN 3 --> negative, no fan is running ( when it shut be in full power i guest...)
    Is there someone that know the solution of this problem?
    milton keynes
    When I had fan issues on my old vectra c , I sprayed WD40 onto the engine ecu contacts , I never had any issues after this.
    Sep 2010
    Belgium (zemst)
    Where is the position of this engine ecu? I have allready checked the big rectangular plug between the fan's (fan control unit)
  1. 1.9cdti 120hp REAL engine code?
    By cphaza in forum Engine & Drivetrain
    Last Post: 22nd November 2011, 15:51
  2. DPF problems on a 120hp. HELP!!!!!!!!!
    By N2B in forum Engine & Drivetrain
    Last Post: 18th August 2011, 16:41
  3. Replies: 27
    Last Post: 30th July 2011, 17:59
  4. 2.0T Engine problems...?
    By n_hudson in forum Engine & Drivetrain
    Last Post: 4th February 2009, 17:43
  5. 1.8 SRI engine problems....
    By bigd1975 in forum Engine & Drivetrain
    Last Post: 12th May 2007, 19:59
