Thread: egr and boost sensor location (with pic)
    hull
    Default egr and boost sensor location (with pic)
    hi all, can you tell me if i'm looking at the correct parts?? gonna have a go at cleaning them.
    egr valve (circled red, arrows to bolts to undo)
    boost sensor (circled yellow)
    it looks like the egr valve has to be removed before i can get to the bolt to remove the boost sensor, is this correct??
    Regular Member daddyjay's Avatar
    Jan 2010
    poole
    Vehicle : vectra facelift
    Trim : sri
    Engine : z20net 2oltr turbo
    Year : 57
    Mileage : 38200
    looks correct mate and yes egr off to get to the sensor..
    hull
    Quote Originally Posted by daddyjay View Post
    cheers mate, wanted to just clean the boost sensor but may as well do egr if it has to come off.
    Regular Member Mission1979's Avatar
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    Don't do what I did the other day when I decided to clean them both, get carb cleaner in your eye. ****** hurts. Cracking stuff though. Amazing how much stuff comes out of the boost sensor.
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    The EGR has the two bolts you have highlighted in red, then there are two at the bottom aswell, then see that metal corrugated pipe that needs to come off too (dont loose the gasket) then there is another one below too that connects upto the top of the exhaust manifold (dont loose this gasket either!)
    While the EGR is off you may aswell take out the throttle body and give the throttle butterfly a clean up and make sure it moves ok.
    Then yes its easier to take the boost sensor off when the egr is out of the way.
  1. boost sensor location?
    By chowwie in forum Engine & Drivetrain
    Last Post: 30th September 2010, 08:00
  2. pressure boost location.
    By leeson in forum Diesel Engine related
    Last Post: 18th September 2010, 21:29
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. Location of boost valve
    By broadgates in forum Engine & Drivetrain
    Last Post: 19th April 2009, 20:45
  5. cleaned boost sensor and still shows over boost
    Last Post: 14th November 2008, 09:23
vectra c 120 cdti boost sensor location
