Thread: Debadging Vectra SRI
    Regular Member VikingLammy's Avatar
    May 2012
    Woolwich
    Vehicle : Vectra Vxr
    Trim : Vxr
    Engine : 2.8 (280)
    Mileage : 59.000
    Default Debadging Vectra SRI
    What is the easiest way to debadge without the mess, also are the badges glued or screwed? Vectra sri
    Regular Member tonci26's Avatar
    Apr 2011
    belgrade
    Vehicle : vectra c gts
    Engine : 1.8 petrol and lpg
    Mileage : 169000 km
    i think all the badges are glued with double sided tape. the easiest way is with nylon.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Wash the area well so you have no grit in between the badges.
    Get a hairdryer and heat up the badges (well the glue really) and as your doing it slide a credit card behind..
    Then once the badge is off - keep applying heat and peal off with the card..
    then polish area and job done.
    Just done my vec estate all round.
    Regular Member MattVecVXR's Avatar
    Mar 2012
    Torpoint, Cornwall
    Trim : VXR
    Engine : 2.8 V6 Turbo (280)
    Mileage : 82000
    I warm the area with hot water on a microfibe cloth and use a length of fishing line to slide underneath. Once it's off, I used tar remover to clean of any remaining adhesive, then clean it again before polish and waxing.
    scottish region
    I used boiling water and a card and it feel straight off then just some srp and wax
    May 2012
    Woolwich
    Trim : Vxr
    Engine : 2.8 (280)
    Mileage : 59.000
    thanks for the advice, i have an estate too
    Regular Member CK1's Avatar
    Oct 2011
    Dublin
    Just did mine today.
    Hairdryer and Dental floss as recomended by someone on here.
    Removed any residual glue with Electrolube LRM label remover which didn't affect the paintwork.
    Polished the remaining ghosting with Turtlewax.
    Looks good.
    Now for the front............
    Essex
    Did mine today
    I used a wall paper stripper just with the hose attached and the badges more or
    less fell off , even the little bit of adhesive left just wiped away !
    After that just use some cutting polish to get rid of the ghost marks.
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Hair dryer, credit card and Auto Glym tar remover. then waxed the paintwork and duraglit on the boot strip.
    HTH
    Stuar
    May 2012
    Woolwich
    Trim : Vxr
    Engine : 2.8 (280)
    Mileage : 59.000
    Sorted, i used a hair dryer and an old bank card then abit of T cut. Looks nice now
  1. debadging
    By V6T H in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2011, 09:20
  2. Debadging my car
    By connery-sri in forum Styling
    Last Post: 8th May 2010, 17:35
  3. Debadging
    By affirmation in forum Styling
    Last Post: 30th October 2009, 19:35
  4. debadging
    By Big Knox in forum Styling
    Last Post: 18th March 2009, 18:13
debadging vectra c
