Thread: DTUK Green box query
    May 2012
    Dundee
    Default DTUK Green box query
    Hi all,
    Had a brief play with a mates DTUK eco green box today. His is an identical car, same model year similar miles etc. His runs on setting 9 and so I thought that'll be reet for mine (I know.....I didn't think that through! )
    Started and idled fine, puff of smoke on acceleration so I was pulling over to wind it back when the car cut out and wouldn't restart. Got it towed back and came up with P0090 Rail Pressure Sensor DTC. Diesel everywhere so I'm thinking pump/injectors/fuel rail ££££ in fact it had blown a pipe off the back of the pump.
    Now I'll admit to my buffoonery for not starting off on setting 7 like the manufacturer recommends but is there really that much pressure difference between 7 and 9 - seemed fairly poorly. I generally read most peeps running them on 8/9 or beyond, was this perhaps just a weak connector or something cos I'm not rushing to try it again on a lower setting or otherwise!
    Cheers for any thoughts
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Sounds like a weak connector but the pressure in the fuel rail is HUGE. The injectors won't activate if the pressure in the rail is below 300bar/4300psi if I remember right.
    May 2012
    Dundee
    Yep agreed, common rails are scary high pressure, I was just a little confused why the pressure was that much more and popped the hose off within a couple of hundred yards.
    My concern with trying one again is what else is going to give up the ghost; is it going to send anything else to an early grave.
    Aug 2010
    Stoke on Trent
    Been running on 9 for the last 40k miles with no issues.... yet
  1. Whats the difference between dtuk green and dtuk red?????
    By srinav in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2011, 10:04
  2. DTUK Green box and DPF?
    By lee gsi in forum Diesel Engine related
    Last Post: 23rd October 2010, 19:01
  3. DTUK Green box???
    By biscuitman in forum Diesel Engine related
    Last Post: 26th April 2009, 13:34
  4. DTUK Green Box
    By Gaz the Cab in forum Parts for sale
    Last Post: 6th October 2008, 14:24
  5. DTUK Green
    By Gripper in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2007, 23:47
