Thread: 1.9cdti Cambelt Change - 'Top Dead Centre' Question...
    Wales
    Default 1.9cdti Cambelt Change - 'Top Dead Centre' Question...
    This coming weekends job is cambelt & water pump change!
    The only thing that I am not certain on is finding 'Top-Dead-Centre' on cylinder no. 1.
    I intend to mark everything up with tippex - pulley position relative to belt and belt & pulley position relative to point(s) on engine. I intend to line the camshaft pulley up with the markings on the engine too (I dont think there are crankshaft markings on the 120 engine)
    So my question is therefore ..
    a) does TDC really matter - if all you are esentially doing is taking the belt of and putting a new one on (and nothing moves in the process) then is this just a red herring?
    b) if you want to find TDC on a derv without pulling things half the motor apart, how?
    Thanks in advance (N.B. this is the 120 engine FWIW)
    Engine : 1.9 CDTi
    Just set the crank pulley so its on its markers and tip ex the camshaft pulley.
    East Ayrshire
    Trim : SRI XP1
    As lee said, Not essential to find TDC. But make sure you mark it up well
    Wales
    Thanks both - you have just reaffirmed my thoughts.
  1. Replies: 25
    Last Post: 15th July 2012, 08:05
  2. Cambelt change on a CDTI 150 Question
    Last Post: 6th March 2012, 21:18
  3. Vectra c 1.9cdti (dead not turning/cranking)
    By Jaybee-le2 in forum Engine & Drivetrain
    Last Post: 14th April 2011, 18:34
  4. locking the engine for cambelt change 1.9cdti 150
    By gasmangt3 in forum Engine & Drivetrain
    Last Post: 12th September 2009, 15:25
  5. Cambelt Change On 2004 Vectra 1.9cdti Sri 150
    By PAULMAC77 in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2008, 11:24
vectra 1.9 cdti tdc
