Thread: BC - Have I got a problem ?
    Regular Member dexter69's Avatar
    Apr 2012
    Stirling
    Default BC - Have I got a problem ?
    So, I filled up with standard Esso fuel this morning - and have driven 50miles...40 on motorway with cc at 65mph, the rest 30mph, but my BC is showing the attached...
    It's never been that high before, so just wondered if my BC is playing up ?
    1.8 petrol (2009 reg)
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    In our 1.8 I did 500 miles to the tank at 62mph on cc and I had an engine block in the boot, so i would expect that milage.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Wow that is quite a high reading "Instant Consumption" lol
    On tick over mine reads about 0.1 miles/gal
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    Quote Originally Posted by Damo77 View Post
    could be going downhill at the photo time etc
    Year : 55
    Mileage : 92,000
    Very true, good point nige
    Apr 2012
    Stirling
    LOL - No 1 child managed to take the photo as I was coming to a stop at a junction...
    Feb 2011
    Selby
    You should be able to get over 50mpg from a 1.8. Give this a try - reset the BC counters, then go for a drive. Change up at 2000rpm, change down at 1200rpm. Accelerate gently, and slow down using the engine rather than the brakes (which means leaving a larger stopping distance so you can react). Do 56-60mph rather than 70mph on dual carriageways, unless you have to overtake something going less than 50mph. Don't use cruise control if there are hills. Basically aim to do everything smoothly and calmly. Makes for dull driving though!
    Instantaneous Consumption isn't that useful to look at, as when you're decelerating the engine's using little or no fuel, so it goes up to silly values (999.9mpg) at times. It's worth resetting the range and other BC counters when you fill up every so often. Otherwise the average consumption is over such a long period that it won't show any difference even if you change your driving style.
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
