Thread: Front Anti-Roll Bar HD Droplinks - Torque Loading
    Regular Member wafoo's Avatar
    West Sussex
    Vehicle : 1.8 Life
    Trim : Life
    Engine : Z18XE
    Default Front Anti-Roll Bar HD Droplinks - Torque Loading
    Have just fitted a pair of Meyle droplinks (Polyflex ARB bushes to be done later) and have tightened the nuts as best I can using an 18mm ring-spanner and a 5mm Allen key in the end of the bolt but I don't know whether or not they are tight enough.
    How can the nuts be torque-loaded to 65Nm, apart from using an 18mm crowsfoot? If the car's weight is taken on the wheels would that prevent the joint from turning? And are the nuts accessible with the wheels fitted and the car on the ground?
    Any advice would be appreciated.
    I haven't tested the car yet but one of the old joints has some play so I'm hoping it will cure the clonking noise evident when driving over holes in the road.
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Tight as you possibly can with spammer will be ample mate ;-)
    West Sussex
    Vehicle : 1.8 Life
    Trim : Life
    Engine : Z18XE
    Thanks for the advice Critch. The new nuts provided by Meyle are 'distorted thread locknuts' so once tightened shouldn't loosen off. The ARB bushes I have ready to fit are, of course, Powerflex not Polyflex.
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    just done my Meyle drop links two weeks ago and tightened them to as much as I could do using a spanner, no problems
  1. Front Anti-Roll Bar New 25.2mm
    By paulhb in forum Parts for sale
    Last Post: 7th March 2010, 14:14
  2. Anti-roll bars/droplinks
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2009, 16:41
  3. Front anti roll bar
    By Tom Tom in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2009, 18:38
vectra c anti roll bar drop link torque
torque setting for anti roll bar links vectra
what is the torque for vauxhall astra anti-roll bar
corsa c drop link torque
meyle hd drop links review
