Results 1 to 2 of 2
Thread: Pistons
    Aug 2011
    Bristol
    Default Pistons
    I am going to do a compression test on my Signum soon as I may have worn piston rings.
    Does anyone know where to buy aftermarket Pistons so I can compare prices if I go down this route?
    Is there anything else that should be changed if I were to do this (headgasket for example, rebore engine etc.)?
    My Signum has done 134,000 miles. If it turns out to be an engine rebuild/refurb what does this involve?
    What price would this be on average and what would be done?
    Dec 2011
    Seaham
    Do the compression test on each cylinder, then squirt some oil into the bores and test again. If the readings go up significantly then its bores/rings.
  1. Caliper pistons - which tool ?
    By Sparky67 in forum Suspension, Wheels & Brakes
    Last Post: 18th November 2016, 02:11
  2. changing discs and pads, pushing pistons back.....
    By taffy bhoy in forum Suspension, Wheels & Brakes
    Last Post: 9th October 2012, 22:33
  3. Pistons need changing if Valves have hit!?!?!
    By Coupe2T in forum Engine & Drivetrain
    Last Post: 5th September 2011, 11:57
  4. totating rear brake pistons but not going in - HELP!
    By circushead in forum Suspension, Wheels & Brakes
    Last Post: 31st January 2010, 18:06
