Thread: can anyone help please
    May 2012
    WEST YORKSHIRE
    Default can anyone help please
    I only have the 1 key for my vectra and when i bought it i was aware the battery was flat in the keyfob.I have just bought a new battery (same spec) and done the key in ignition procedure to reset the key but nothing happens.The key opens the drivers door but none of the others and the alarm doesnt go off when i open up.Its a pain any ideads guys?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Have you tried to press the button twice? Your car maybe set up for 2 stage opening.
    When you say the alarm doesn't go off, do you mean it doesn't deactivate or it doesn't make a noise
    May 2012
    WEST YORKSHIRE
    Ive tried it twice and it doesnt work.it doesnt make a noise.the central locking works from the switch on the drivers door though but no response from the keyfob.thanks
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Sounds like the keypad on the remote may be knackered then
    May 2012
    WEST YORKSHIRE
    Is that an expensive do? and is it a main dealers job.thanks again
    What type of key do you have?
    As a 2005MY, you probably have the older panel key rather than the newer flip type
    One of my originals failed, but VX refused to replace it "as the lock still works"
    I decided to buy a replacement, as they confirmed it would be the newer type
    If going to dealership they will ask for both keys, which you really should have
    You will also need the passcard
    If you don't have the passcard then you will need one form of ID (Driving licence is acceptable) and the V5 so that a replacement can be ordered and obtained
    Typical price to replace and program one key is about £140 (excluding the cost of obtaining a replacement passcard if required, but I would haggle hard over that, as both will be required to complete the job)
    May 2012
    chelmsford
    Hi there. Try disconnecting the battery for 5 minutes. Remember radio code though. Re connect battery and try again sometimes that resets it
