Results 1 to 10 of 30
Thread: Rear passenger inner tyre wear
    Aberdeen Scotland
    Default Rear passenger inner tyre wear
    Hi I have had a squeeking noise from my rear passenger side for a while so i thought it was rust in the brakes, so at the weekend took the wheel off and tried to look for any problems with the pads or shield around disc but couldnt see any problems. Copper greased parts up that could be making the noise. As I was putting tyre on the inside of the tyre tread is almost gone and at some parts it is gone. The rest of the tyre is like new as recently replaced only 5 months ago. Couldnt see any other problems with wheel off. The squeeking noise is only when moving about 10-15mph in traffic at speed there is no noise. Any ideas have searched it and links to upper control arms, etc. The spring is new last year. What should i look for and what can i check, thanks.
    Aberdeen Scotland
    Forgot to add the 3 other tyres are good as new still.
    Does the squeeking occur when moving or when braking?
    Try lifting the rear offside arch, then release, is there any noise?
    Aberdeen Scotland
    Hi when its moving , but when i move at low speed if I put the handbrake on it stops squeeking thats why i thought it was the breaks but thta doesnt account for the excessive tyre wear, will have to try lift arch tonight thanks for the reply.
    Aberdeen Scotland
    Is there anybody else with any other ideas?
    Upper control arm
    Bush worn
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    upper control arms
    and bushes as mentioned above and look at the camber settings for the rear tyres aswell
    Aberdeen Scotland
    Thanks for the replies do I need to replace both bushes and upper control arms or just the side that is affecting the tyre wear,thanks?
    Oct 2009
    Luton
    Best to replace both sides - grab the top of the inside of the wheel and try pulling / jerking it and you should hear / feel knocking if top arms are goosed.
    Beware of cheap fleebay items they last 12 months at best & it's a pig of a job to do.
    Aberdeen Scotland
    does the bushes come with the control arms? Or are they seperate items? Thanks.
  1. Rear tyre wear
    By Geoff644NI in forum Suspension, Wheels & Brakes
    Last Post: 29th March 2011, 22:00
  2. Which rear part causes tyre wear?
    By stuartbat in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 22:19
  3. Rear Tyre Wear
    By johnmac in forum Suspension, Wheels & Brakes
    Last Post: 28th June 2008, 22:20
  4. Rear tyre wear
    By nhoj in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2008, 15:10
  5. Rear tyre wear Vecta 03
    By gordonc in forum Suspension, Wheels & Brakes
    Last Post: 24th June 2007, 16:52
