Thread: Headlight protector removal
    May 2012
    UK
    Default Headlight protector removal
    Hi all
    My Vectra came with the OEM headlight protectors fitted, look like they've been on from new as the headlights are a tad dirty underneath.
    Does anyone have any idea how to remove them?! There is only one visible screw and they look like they are secured underneath the headlight. I don't want to pull the too hard in case I break them
    Jul 2011
    UK
    Year : 06
    Remove the headlights from the car should be another screw under the light unit
    May 2012
    UK
    Quote Originally Posted by marc vectra sri View Post
    Oh no I was hoping it wouldn't be that! If the lights are removed do they have to be re-aligned when they are refitted?
    Seems mad to have to do that just to clean them... thanks Vauxhall!
    Jul 2011
    UK
    Year : 06
    No alignment need done just need to drop the bumper the get to the bolt under the bumper
    I might be wrong how the protectors are on but uselly they bolt on under aswell
    May 2012
    UK
    Cool thanks, I'll take a look - might leave them unbolted at the bottom or find another way to secure so I can whip them off for cleaning in the future!
    I guess while the lights are out I can upgrade the bulbs
    Regular Member Keif's Avatar
    In the Garage
    I have headlight protectors fitted in the winter to my pre-facelift Signum. There is only one screw holding them on.
    Like so.....
    The bottom just slides under the headlight, so should just pull out.
    Not sure if you have a pre or post facelift car.
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    As Keif says, mine are the same, one screw at the top, then gently tilt and pull towards you, no fixings underneath unless facelifts are different?
    May 2012
    UK
    Thanks guys, my Vec is a facelift but the basic design is the same as in the image - I'm going to try to take them off on Wednesday so will post back.. if it's possible to take them off without removing the bumper that will be a result
    Verwood Dorset
    Facelift models identical. Remove the top screw and pull away gently from the bottom of the headlight. Have had them fitted to mine for 5 years now with no problems.
  1. headlight protector fixings
    By nikroc in forum Bodywork & Interior
    Last Post: 29th November 2009, 21:02
  2. Estate rear bumper protector removal
    By Inner Zone in forum Bodywork & Interior
    Last Post: 1st February 2009, 14:28
  3. Any pics of headlight protector fitting
    By installer in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2005, 18:12
