Thread: MOT
    Regular Member fiend61's Avatar
    Nov 2011
    york
    Vehicle : vectra 2.8 turbo
    Trim : elite
    Engine : 2.8 turbo
    Default MOT
    oh well the old girl went through her mot yesterday and she passed couple of advisarys i would like help with though please
    slight play steering rack inner joints
    offside rear brake shoes low compared to rear nearside brake shoes
    had a word with the tester about the brakes but he said he could find no evidence of binding ???
    as for the steering rack i havent a clue are the inner joints replacable ??? if so gm parts or aftermarket and how much am i looking at ???
    tia
    scotland
    brakes ...... tell him to furk off as it aint got shoes on rear ! simples
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    1 it doesn't have rear shoes an 2 even if it did shouldn't be striping them on MOT anyway lol
    As for inner track jack car up
    Have someone grab wheel @ 3&6 o'clock position an wiggle while you hold on to steering rack gaiter you should feel movement of theirs any play.
    Not a bad job to do. But more awkward on axle stands than a ramp/ pit
    Ive done how too on them.
    Id personally do vxl parts as comes as complete kit with new gaiters clips nuts etc.
    Were as aftermarket literally come just tie bars. And you end up having to cable tie the old gaiters on.
    I no as I did a Zafira on Friday lol
    Quite common for the steering rack joints to need replacing, will last about 2K miles before they are worn and need replacing
    The tester has probably picked up the text for shoes instead of pads
    Quite common due to Traction Control applying the brakes independently
    If it is a ABS issue, then the nearside front will be worn, compared to the offside front
    You should be able to visually inspect the pads, so just replace them when worn and fully inspect all parts
