Results 1 to 10 of 19
Thread: EXHAUST flexi pipe
    Mar 2012
    gloucestershire
    Default EXHAUST flexi pipe
    Has anyone had a problem with the above named part.
    Whilst driveing my car i noticed it sounded a little different. On checking under the car i noticed what looks like a flexi pipe just in front of what i think is the first cat and just after the down pipes. The flexi pipe is freely moveing at both ends..
    Do i need a new section or can this be fixed easy
    Any help you guys can give would be greatfull
    Jan 2008
    ipswich
    Unhappy hi
    hi mate when i had to change mine my car sound like she was running heavier and you can see. all the soot from around the front of the car when clean out from the flexi as it had a hole in
    Mar 2012
    gloucestershire
    Thought my car was sounding different. Suppose I will have to look around to sorting the pipe out.
    Did you manage to get just the flexi pipe.?
    I notice you can buy replacements which you can get welded on or clamped
    Regular Member Dai69's Avatar
    Nr Welshpool
    Vehicle : Vec C Estate X 2
    Engine : CDTi 150
    Year : 55&56
    Mileage : MANY
    Section between the DPF and the cat went on mine. cost about £35 and was just a case of unbolting the flanges front and back and throwing the replacement part in with new gaskets. Pretty easy job, but a pain in the arse if you're trying to do it on the drive as the top bolt on the rear flange in near impossible to access.
    Have fun
    Mar 2012
    gloucestershire
    Will this I be able to do what you did to you car?
    Mines a 2004 gsi.
    Anyone any ideas where to get the part from and part number. And price.
    Mar 2012
    gloucestershire
    Just rang vauxhall for a price. Nearly £600 for the part as it has the two down pipes
    and the cat with it. . Not what I need with a new baby on the way.
    May 2012
    WEST YORKSHIRE
    try ebay and look for the same model breaking,you may be in luck.would save you a bomb
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Go to a local custom exhaust place, they will weld in a new flexi for about £75-£100
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Just had one fitted, new part from cat to centre section inc flexi, 70 fitted. Take no notice of dealers!
    Mar 2012
    gloucestershire
    Quote Originally Posted by Jow20 View Post
    Where abouts did you get yours from.
  1. flexi pipe
    By datiger79 in forum Engine & Drivetrain
    Last Post: 18th January 2012, 17:27
  2. Flexi Exhaust Pipe
    By SarahP in forum Vectra C / Signum Troubleshooting
    Last Post: 1st January 2012, 20:14
  3. exhaust flexi pipe
    By yorkshireborn in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2011, 14:57
  4. Exhaust flexi pipe
    By andsaw in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2011, 18:41
  5. Exhaust-Flexi-Pipe Broken
    By Dreamyhose in forum Engine & Drivetrain
    Last Post: 16th October 2008, 09:27
can i drive my vectra with broken flexi pipe www.vectra-c.com
