Results 1 to 2 of 2
Thread: cdti oil filter removel
    Dec 2010
    IRELAND
    Default cdti oil filter removel
    I am going to service my vectra cdti during the week i removed the engine cover today and located the oil filter housing i attempted to loosen it a bit with a 32mm socket it wouldn't budge and i found it hard to get a turn on my ratchet is there an easy way off getting the filter off ?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    take the coolant tank out of the bracket so you can get your hand in etc. better.
    You will need something longer than your ratchet. I use my broken torque wrench that I use as an 'undo' wrench for things like wheel bolts etc... You just need a bit more leaverage. Moving the coolant tank just gives you the access you need.
    remember that when you install the new one (with new rubber rings) - 25nm of torque only
    HTH
    A
  1. Replies: 6
    Last Post: 26th June 2012, 10:58
  2. Sri boot lip spoiler removel
    By pipamish in forum Bodywork & Interior
    Last Post: 18th March 2012, 06:44
  3. Diesel pump removel reconditioning
    By bryant1066 in forum Engine & Drivetrain
    Last Post: 25th January 2011, 23:19
  4. seat stains removel
    By yadziyad in forum Bodywork & Interior
    Last Post: 13th July 2009, 13:29
  5. rear bumper removel
    By david-bell in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2007, 00:08
