Thread: Drivers side mirror has fallen out
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default Drivers side mirror has fallen out
    Cleaning the car today my drivers side door mirror decided it didn't want to be their anymore does anyone know if it can be glued back or do I need a new part
    PRESTON
    Quite common on Vectra i'm afraid, however, if the plastic backing is still in the mirror, then yes just glue it back in. I understand some of our members have used sillicone to stick the glass back in.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Bit of superglue an it'll be reet
    Did that to my passenger mirror last year an still ok.
    Failing that, Halfords sell stick on ones
    May 2012
    NW UK
    Decent double sided sticky tape should work too.
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    Impact Adhesive works very well..
    Nov 2010
    East Midlands
    Trim : design
    Get a tube of black silicon from Screwfix stays flexible and waterproof - only a couple of quid - best way to stick the mirror back in and you will have loads left for when the other side falls out - which won't be long
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    common fault as mentioned above. always seems to happen when you have just washed the car
    it seems that when using your heated mirrors through the winter. seems to dry the glue
    it happened to me aswell i used bostik glue its been ok for the last 3 years
    there have been a lot of threads on here about the mirrors falling off
    11 Post(s)
    Quote Originally Posted by Critch View Post
    You're lucky then.
    Superglue doesn't allow for expansion and contraction. Hence why it's unsuitable for sticking rear view mirrors back on as it can result in cracking the windscreen.
    May 2006
    scotland
    Mine fell off after a while with superglue. 'No more nails' and all is well.
    Aug 2009
    South Yorkshire
    I stuck mine back in with decorators caulk...it was all I had to hand at the time and its worked perfectly. Not fallen out yet anyway!
  1. Drivers side wing mirror
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2008, 16:27
  2. Drivers side mirror
    By Steve-E in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2008, 20:57
