Results 1 to 10 of 17
Thread: Reset Engine Fault light
    Regular Member jamesr's Avatar
    Lancashire
    Default Reset Engine Fault light
    How can i reset the fault light??
    two methods.. either take it into the dealers, or disconnect the battery for 10 minutes.. if the fault isn't still present then the light will stay extinguished..
    just remember to reset the power windows one touch facility..
    Lancashire
    Thanks!
    To disconnect the battery is it the same as on the Veccy B?
    Ie key in ignition then remove battrey within 10 secs?
    Regular Member Madgunner's Avatar
    Worrying bout nothing..... Cause worryings a waste of my f***ing time!
    I disconnected mine Monday to try & clear the steering wheel light just undone the earth from the battery left it for about 20 min then reconnected it. did'nt put the key in the ignition m8
    As above..
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    How do you do that mate?
    wind them down a touch..say about 3 inches..
    then push and hold down the 'up' switch to wind the windows up and carry on holding it down for about 5 seconds.. then the windows will have regained their memory.. do this for each individual electric window on the car..
    they will then be 'one touch' again..
    hold the window down button til the window reaches the bottom then press the up button till the window reaches the top & keep the button held for a few seconds after then it sets the one touch operation. do this on each window m8
    ok yours is better than mine i thought you had to do it all the way down
    Beat yer..:..
  1. Replies: 2
    Last Post: 10th September 2012, 19:09
  2. Engine fault light on / Juddering when hot
    By Angelchops in forum Engine & Drivetrain
    Last Post: 17th September 2011, 19:16
  3. Reset Engine Management Light
    By guygreen in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2010, 18:53
  4. Engine fault code reset
    By papz in forum Vectra C / Signum Troubleshooting
    Last Post: 21st June 2009, 18:44
  5. help please engine fault light
    By beefycol in forum Engine & Drivetrain
    Last Post: 31st December 2007, 01:51
how to reset engine fault vectra
