Thread: A waste of £40 or not???
    Regular Member 111's Avatar
    Stockton-on-Tees
    Default A waste of £40 or not???
    Do you think I am just wasting £40 by fitting a fuel comp & indicator stalk out of a 2004 SRi 2.2 petrol to a sxi 2.2Dti??? Will it work??
    it would depend on the display and if your car has the trip computer already installed.. if you're just thinking of putting a switch on to make it work, i'd think it was unlikely..It may be possible to enable it via Tech2, but the stalk you need is the right hand side one..the left hand side is cruise control/indicators, the right hand side is Computer/wipers..
    Stockton-on-Tees
    Sorry I ment the right hand stalk. Mine has the standard computer at the mo, With the little screen, Temp, time & radio display. Mines a 2004 53
    the normal trip computer uses a different display.. but i'm not saying it's impossible.... just a little more to it than just plugging a stalk in.. dependant on the cars loom, it may not even be wired for trip computer....
    Stockton-on-Tees
    It is the full computer unit and the bigger screen From between the middle vents that would be fitted as well as the stalk, it just seamed a good price for the bigger computer unit & stalk. Just my luck. I should have gone for the 3.0cdti sri.
    Regular Member Ross DTi 2.2's Avatar
    Münster, NRW, Germany
    It can't be done, well not easily anyway. I tried it on one of my 1.8 LSs, they have the same TID display as your SXI as opposed to the one you want to fit, the bigger GID.
    The plug on the loom that goes to the TID is different from the one required for GID.
    Hope that hasn't confused you too much.
    It can be done but will require loom swaps and Tech 2.
    Stockton-on-Tees
    Bummer, I'll give it a miss then . Thanks for the info
  1. What A Waste = But So Lucky .
    By HITFACTORY1403 in forum The 'Off Topic' room
    Last Post: 16th January 2013, 14:09
  2. Well that was a waste of time
    By VECTRA HEAD in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2012, 18:33
  3. How to waste one hour
    By m8internet in forum The 'Off Topic' room
    Last Post: 2nd April 2011, 12:00
  4. Waste of a very nice car.
    By no1golfer in forum The 'Off Topic' room
    Last Post: 27th October 2010, 19:39
  5. What a waste....
    By Big Davie in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2006, 11:41
