Thread: Some advise please
    May 2012
    Dundee
    Default Some advise please
    The usuall water pump seized threw timing belt broke 14 rockers the 2 that didnt break bounced the 2 valves.anyway replaced the valves all 16 rockers water pump timing belt put all back together now it turns over like there's no compression.its letting air and diesel out the side of the injectors replaced copper washers what else do I need to do
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 134000
    May 2012
    Dundee
    Turned it over by hand few times even bought the timing tool kit still no joy
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 134000
    you could pm
    djr69uk in the first post
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The OP has fixed the pump and followers so the symptoms are not the same, he has a sealing problem with the injectors
    Anyway, I had the same problem with my cdti when replacing the injectors.
    Did you clean the bores so that they were spotless before fitting the injectors? Another point is, are you using a torque wrench?
  1. Advise please
    By Pulja in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2011, 17:28
  2. advise please
    By steve66 in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2010, 20:37
  3. BMW Z3 2.8 advise pls
    By wardy in forum The 'Off Topic' room
    Last Post: 4th September 2010, 23:22
  4. Looking for some advise
    By Gortreck in forum Engine & Drivetrain
    Last Post: 17th September 2009, 12:46
  5. New TV , advise please
    By SteveH in forum General Chat
    Last Post: 17th December 2008, 14:03
