Thread: Going to view a 1.9 150 SRi tomorrow, advice appreciated!
    Jan 2012
    Dublin
    Default Going to view a 1.9 150 SRi tomorrow, advice appreciated!
    In the morning im going to have a look at a 2007 sri with the 1.9 150 engine. What should I look out for? I know to check for a rattling dmf and that the swirl flaps in the inlet can be dodgy. How can i check the inlet? Any other common issues?
    Any advice much appreciated!
    Regular Member smartalec0310's Avatar
    Apr 2012
    littleport
    to check the inlet take the engine cover off and look between the block and then inlet there should be a bar running along it use a torch or light from a phone to help. other then that just dmf i suppose, mines almost had it.
    Jan 2012
    Dublin
    Quote Originally Posted by smartalec0310 View Post
    any tools needed to pop the engine cover off? Sorry never been under a C bonnet
    Jul 2011
    UK
    Year : 06
    No tools just pops off its on lugs
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Check the wiring for the injectors - if yellow it will be the old ones and therefore vulnerable to the 3rd injector failure issue. This a fault with the yellow type plugs, upgraded ones are blue.
    Go for a test drive, if the car is sluggish under 2,000rpm the EGR valve may be choked up or one of the vacuum pipes may have split (easy and cheap enough to replace).
    Jan 2012
    Dublin
    cheers guys, anything else to look out for?
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by IrishVectra
    Rear banana arms try move the rear wheels while on the ground
    Wipers park correctly and not in middle of screen or loose
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    If you want to be a little picky, You can look through the front bumper to see the state of the condenser as it takes a beating. Or just check the AC from in the cabin, make sure its cold.
    As others have said though, Inlet manifold (swirl bar) Have a look on the forum for what you are looking for, there are loads of image's regarding it. Injector Wiring, oh and dont forget the thermostat! They tend to fail on these sometimes. If looking at the rear tyres, check the inner edge also, They have a bit of a camber on the rear, so may look like they have tread on the outer, but may not on the inner edge.
    The engine cover just pulls off, but when replacing, put the rubber parts onto the cover then push back onto the top of the engine. Dont want to break it now :P
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    check if the cambelt has been done and waterpump if high miles
    check the heater works on all settings
    as the people above said dmf Intake manifold/swirl valves these are the most expensive parts to replace
  1. running problems - any advice appreciated :)
    By Ian436 in forum Engine & Drivetrain
    Last Post: 30th July 2012, 20:44
  2. Silly Question but Advice Appreciated
    By quarkrad in forum Engine & Drivetrain
    Last Post: 9th February 2011, 14:06
  3. Anyone used these/advice appreciated
    By Bullylad in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2010, 16:40
  4. advice on rear view camera
    By tony stoney in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2010, 22:14
  5. BROKEN DOWN!- Any advice appreciated!
    By pjames.79 in forum Engine & Drivetrain
    Last Post: 30th January 2008, 12:44
