Thread: Bleeding Vec. 150 ?
    Jul 2011
    Leeds
    Vehicle : Insignia 160
    Trim : Elite Leather Light n Sight
    Engine : 2.0 16v
    Year : 2012
    Mileage : 50k
    Default Bleeding Vec. 150 ?
    Having had the misfortune of running out of Diesel in my old Vectra 'B' DTi and the day from Hell.
    Being towed for about 3 miles before she fired up,and hoping I wouldn't wreck the pump.
    I was wondering how easy/hard it is to restart a Vec 'C' 150 when run dry ?
    I know there is a low pressure pump in the fuel tank to take the fuel to the high pressure pump but.........
    Has anyone had to do it and if so, is it just like a petrol or is it still an effort to get going again ?
    Hope it never happens, but I would just like to know !
    Thanks.
    Regular Member bigdave1701's Avatar
    York
    I think the issue with the DTI is when the diesel runs out it pulls air into the fuel lines which is a pig to bleed out. The cdti bleeds itself so shouldn't have the same issue.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    First off don't run dry. You get three warnings, fuel light on , then flashing fuel light plus warning from the Board Computer so no excuse really.
    If you do then its easy to get started again, turn the ignition all the way on but do not start the car. Wait until you hear the pump priming noise stop. Do this twice more then start the car and all should be fine.
    Only problem with this is you drag all the crap from the bottom of the tank in when you run out of fuel and this can cause issues in the future
    Aug 2010
    Derbyshire
    As post above it will prime itself once you've put some more diesel in.
    Took my filter off yesterday and once back together with a new filter one turn of the key and it primed and fired up.
    Mick
    Jul 2011
    Leeds
    Engine : 2.0 16v
    Year : 2012
    Mileage : 50k
    Default Thanks for that.
    [QUOTE=MickAP;1815097]As post above it will prime itself once you've put some more diesel in.
    Did you not have to fill the filter housing with Derv ? That sounds brilliant !
    As for crap in the fuel tank,what crap ? I thought they were plastic so no rust.
    I used to make plastic petrol tanks for Nissan's,we once had one sent back with a leaking problem.
    When we cut it open with a 'Zipper' to check the plastic welds inside, all's we found were a few alloy particles which were from the filler nozzle at the fuel stations.
    That tank was 7 years old ! It had been back and forward on warranty to the Nissan dealer,then sent to us (on request) by an Independent garage.
    Turned out to have a carbon inclusion in the wall of the tank,from manufacture. Only leaked very occasionally on very hot days (pressure related).
    But no crap at all in the tank,and it was from a 7 year old car !
    This must only be from steel tanks that don't get brimmed very often ?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Interesting what you say about the Nissan, maybe its an urban myth now about the crap in the bottom. I know it did happen with the steel tanks as I have replaced a couple many years ago. I suppose no one knows whats in the tanks until they are taken off
  1. Bleeding the coolant
    By iRocco in forum Engine & Drivetrain
    Last Post: 2nd February 2014, 18:11
  2. bleeding brakes
    By mon in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2013, 21:50
  3. clutch bleeding
    By bigbossgk in forum Engine & Drivetrain
    Last Post: 11th May 2012, 18:15
  4. bleeding bleeding and adjustment
    By noudder72 in forum Suspension, Wheels & Brakes
    Last Post: 26th December 2011, 11:29
  5. Bleeding brakes?
    By blue estate in forum Suspension, Wheels & Brakes
    Last Post: 21st March 2010, 21:05
how to bleed insignia a20dth diesel
vec150
Dont bleed cdti fuel lines
