Thread: Signum Travel Companion
    Regular Member Yenyaw's Avatar
    Feb 2012
    Hemel Hempstead
    Default Signum Travel Companion
    Hi All,
    I have the opportunity to purchase a Signum Travel Companion which will be great for when i take the kids on holiday.
    What i would like to know is:
    Would this fit in a Vectra C facelift?
    Thanks All
    Regular Member andyco11's Avatar
    May 2012
    staffordshire
    Mileage : 80000
    No Not unless you have the Vectra mounting plate.........which is what i am after as well
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Simple answer no, you will also need a fitting kit which is no longer available from VX. Most of the parts of the kit are not available separate either
    The fitting kit contains wires,bolts and other bits that are specifically made to fit it
    Feb 2012
    Hemel Hempstead
    Is it the same harness/fitting kit for vectra as well as signum?
    May 2012
    staffordshire
    Mileage : 80000
    The multi plug on the two mounting plates i have do fit the multi plug connector on my Vectra C but the mounting plate is way of in size
    Feb 2012
    Hemel Hempstead
    Anywhere i can buy a fixing kit? I have the part numbers that make it up but cant seem to find anywhere thats sell it, not even flebay
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Yenyaw View Post
    No as I said before its unavailable.
    Including in the pack are special screws/runners which the rear of the TA fits into. Without these you cannot fit the TA in correctly.
    I really wish people who are selling the TA's took all the bits of the kit out along with the TA before they sell the car. They seem to think they will fit straight into another Signum, not without the fitting kit they won't!
    Feb 2012
    Hemel Hempstead
    Damn it, good job i havent shed out £90 for it then,
    However he is a member on here, i might see if he has the fixing kit to go with it.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    hopefully he still has the car and can take all the bits out. You will also need the black plastic bit that fits into the floor. If this is removed then it will leave a hole in the carpet so perhaps thats why people do not remove the kit when they sell the car
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    The base is also different and made of unobtainium
  1. Travel Companion
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2010, 23:33
  2. Travel assisstant for signum
    By Pilotboy in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2009, 09:54
  3. Signum Travel assistant, on E-bay
    By HighlandGraham in forum General Chat
    Last Post: 8th November 2005, 00:52
