Thread: Rocker cover leak - urgent help needed!
    May 2012
    UK
    Default Rocker cover leak - urgent help needed!
    Hi all
    Need some urgent advice! When I bought my Vectra a couple of weeks ago there were some signes of oil spillage on top of the engine, primarily around the filler cap which I put down to a slightly careless previous oil change. The front of the engine was also a bit grimy which I also put down to a previous spillage.
    I cleaned the front of the engine but after a run out today there is fresh oil sitting on silver lip where I believe the rocker cover gasket is. Also the black plastic immediately above the lip (see arrow) has a very slight flex in it when pushed - is this normal?!
    Just need to know if the view is that this is likely to be the rocker cover gasket (is it common?!) or if it could be something else - even leaking from the filler cap down. It's on the same side of the engine but I only see new oil sitting on the lip at the front & it doesn't look like it's leaked down.
    Is the rocker gasket a big job on these engines? My car is an '06 1.8 vvt exclusive with 31k miles on it.
    I'm no expert so I'm guessing the circled bolt is one of the retaining bolts, or is this just to remove the top cover?!
    I have took the car over to the dealership and left it with them to sort out, but as it's a Renault/Nissan dealer not Vx I am a bit concerned they will do it right, torque everything up correctly etc. If it isn't likely to be the gasket I would rather them leave it! Is the cover sensitive to torque on these engines?
    Sorry for lots of questions but any advice would be really appreciated!
    May 2012
    UK
    Dec 2011
    Seaham
    I would try just giving the gasket a nip up.
    May 2012
    UK
    Quote Originally Posted by Ben50n View Post
    Yeah I thought about that but was concerned I might damage something.
    Apparently from a very old thread I found this was subject to a recall (fit modified cam cover seal) - I wonder if Vx would still do this recall as the car is 6 years old / 31k miles?
    Dec 2011
    Seaham
    You can contact Vauxhall and ask if your car has been recalled and the remedial work completed?
    May 2012
    UK
    Just got off the phone to them... there wasn't a recall apparently
    At least it's under warranty with the supplying dealer...
    May 2012
    UK
    Bump
    Does anyone else have this oil leak from the same area & is it likely to be the rocker cover seal?
    I haven't taken the cover off but I did read that the oil filler cap can leak, anyone had that issue?
    Thanks!
    Dec 2011
    Seaham
    I have a 1.8VVT and not noticed any leaks.
    May 2012
    UK
    Well, all sorted by the dealer... Hopefully they used gen Vx bits and torqued to the correct level and all will be well!
    Is there any issues if they have not used the correct torque on the cover? Is it possible to back up and re torque without disrupting the seal?
    Regular Member SarahP's Avatar
    Nov 2011
    Buckinghamshire
    was it the rocker cover gasket?
  1. Rocker Cover Gasket Leak Symptoms?
    By john506 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 19:04
  2. Rocker cover
    By Kenny_Exclusiv in forum Engine & Drivetrain
    Last Post: 6th September 2012, 10:31
  3. Rocker cover 2.2 dti sri help please!
    By congaman in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2010, 23:59
  4. oil leak on rocker cover
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2009, 18:57
  5. 2.2 Rocker cover (types) - Intake cover removal
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2006, 20:27
