Results 1 to 10 of 17
Thread: Poor Starting & Thick White Smoke (2.0DTI)
    Jul 2010
    Swansea
    Trim : LS
    Engine : 2.0DTI
    Year : 2002
    Mileage : 165000
    Default Poor Starting & Thick White Smoke (2.0DTI)
    Hello All ,
    My 2.0DTI has started getting harder and harder to start these days I found a quick solution which is not really feasible as i have to take the engine cover off every morning and remove the Plug from the temperature sensor bringing on the glow plugs, doing this it starts like a brand new car.
    When i dont remove the temperature sensor it starts like a tractor.
    I have changed the leak off pipes & the glow plugs but seeing as when the plugs are forced on it starts fine i am not really sure if its the Temperature sensor itself or possibly the relay any ideas? Sounds a bit lumpy in the first vid which i had not noticed before which is why i went to the engine. Thanks in advance and much appreciated.
    Also these videos are the car on start up, top 1 is when i pull out the temperature sensor bottom is attempting to start normally(usually a lot worse).
    Video 1, Temperature Sensor Removed:
    https://www.dropbox.com/s/wmml82f1ex...2016.45.20.mp4
    Video 2, Attempted Normal Start:
    https://www.dropbox.com/s/wnwkzdeuep...2011.27.06.mp4
    Thanks Again
    Nottinghamshire
    Is it like this when the engine is cold and/or warm and/or hot?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I'd say the temp sensor is knackered...
    ---Sent from my iPhone 4 using Forum Runner.
    Jul 2010
    Swansea
    Trim : LS
    Engine : 2.0DTI
    Year : 2002
    Mileage : 165000
    Quote Originally Posted by James24 View Post
    It happens more or less every morning regardless of outside temperature, when the engine is cold(first start of the day) it struggles and smokes. Afternoon after being left for a while it smokes but does not struggle to start. When the engine is warm after a drive starts fine no smoke no struggle.
    Thanks.
    From what i've seen the temperature sensor are fairly cheap so if anything i hope its that ^^.
    Nottinghamshire
    It will probably help. Less that £10 for a genuine one if I remember correctly. I had the same issue and also did the following to sort it out. These all helped to varying degrees.
    The possible root cause (proved by removing the temparature sensor to force a pre-heat?) seems to be the engine not getting a tiny little preheat which it sometimes needs when the engine is warm, either because the ECU thinks it doesn't need one or because a sensor is faulty and leading the ECU to think that the engine is warmer than it is.
    Cleaned MAF (difficult due to security screws, got rid of hesitancy at low revs).
    Replaced crankshaft sensor (helped starting and also smoother running).
    Replaced battery (old one was way down on what it should have been, turns over a lot faster on new one).
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Is there not an ecu software update available for the 2.0 DTi cold start issue? Just remembered seen it on another thread somewhere...
    Jul 2010
    Swansea
    Trim : LS
    Engine : 2.0DTI
    Year : 2002
    Mileage : 165000
    The battery i have is virually brand new, and did all these fixes sort your issue out or simply make it better than it was?
    I also seen the thread somewhere about the ECU update but not sure if the car has had it by the previous owner or how i go about it vauxhall probably charge a fortune.
    Thanks again
    Admin plasma's Avatar
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    Injector seals... when mine used to fire over the whole street filled with white smoke,
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Jul 2010
    Swansea
    Trim : LS
    Engine : 2.0DTI
    Year : 2002
    Mileage : 165000
    Quote Originally Posted by plasma View Post
    I have read about this but i am in denial xD
    Nottinghamshire
    The things I did (including finally replacing the oil temperature sensor at the weekend) have made the car considerably better although it's at it's worst (relatively speaking) at the moment due to the ambient air temperature being just high enough for the ECU to decide that it doesn't need to pre-heat.
    If you leave your car parked with the front end facing downhill, gravity should help stop fuel flowing back towards the tank due to air getting in somewhere. If the car is easier to start then there may well be an air leak somewhere (including the injector seals presumably) but if's its just as difficult to start then maybe the issue lies elsewhere.
    I went to an independent Vauxhall specialist who had a Tech2 and his opinion was that he couldn't see anything (fuel pressure, I think it was) that would indicate an issue with the injector seals. He also said that the 'fix' of removing the coolant temperature sensor wiring connector pointed to the issue not being related to air leaks in the fuel system but due to a faulty temperature sensor or an issue with the software version in the ECU that was not pre-heating when it needed to.
  1. Car starting on ez-start then on its own and white smoke.
    By Stoo2k in forum Engine & Drivetrain
    Last Post: 22nd May 2012, 19:07
  2. thick black smoke cdti.
    By frasedeb in forum Engine & Drivetrain
    Last Post: 16th May 2012, 20:04
  3. White Smoke on Starting??
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2010, 12:47
  4. Help a sick V6CDTI - Thick white smoke
    By Celes in forum Engine & Drivetrain
    Last Post: 28th August 2010, 21:02
  5. poor starting 2.0dti
    By bertmarshall in forum Engine & Drivetrain
    Last Post: 2nd January 2009, 10:50
vectra cdti white smoke on startup
https:www.vectra-c.comforumshowthread.php164365-Poor-Starting-amp-Thick-White-Smoke-(2-0DTI)page2vauxhall dti white smoke2.0dti white smokevectra c white smoke on startupvectra c 2.0 dti smoke when cold2.0 dti zafira smokey startingvectra c 2.0 dti cold start problemsvauxhall zafira white smoke difficult startingvauxhall zafira white smoke difficult starting fixed
