Results 1 to 10 of 16
Thread: Unusual regen for my car.
    PRESTON
    confused Unusual regen for my car.
    Having lived with a CDTI estate for over two years, I know and recognise when the car starts a regen. So, arrived at work this morning, parked up and sure enough she starts a regen. Looked at the time and thought *&&!! don't have enough time to go for a drive and not good to switch off, dilemma!! Held the revs at 2000, instant mpg showing 1.5 gallons per hour and could smell the DPF getting hot, nothing unusual so far.
    Now, I have been here before, but today was the first time in 14 regens that the car park filled with smoke during this process, I actually thought the engine had blown. After ten minutes the regen completed, instant consumption returned to 0.1 gallons per hour, as it should be, engine running sweet and no smoke.
    Have any owners of DPF equipped cars seen clouds of smoke during a regen? as this is a first for my car, she normally doesn't smoke like that during the regen process.
    Aug 2009
    Banbury
    Hi Barney, not had a regen on my vectra as it is a hatch and does not have a dpf. However on my Astra I have and it started when I was pulling away from a roundabout and I noticed in the mirrors what seemed to be a huge cloud of smoke. Assumed it was the regen starting so went for a drive and all was well. Must admit though if you did not know you would think something serious was up. Still think there sould be some indication on the dash that the regen is in progress.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The dash warning was removed by VX as too many owners came in asking what the warning meant! RTFM would have been my answer
    PRESTON
    Quote Originally Posted by merikiito View Post
    I believe that is correct, surprises me they did that, as normally the dealers try everything to get people INTO the dealerships, LMAO!!
    PRESTON
    Quote Originally Posted by Darrin View Post
    Ty Darrin, My car has never smoked during regen, that's what threw me this morning. I fully understand the regen process and what happens, in fact i could write an essay on it, but never seen one smoke. Was wondering if the honeycomb in the DPF has shattered, allowing excess smoke from the overfuelling to pass freeley through it, like when people remove the inside of the dpf without disabling the regen software. Fully agree there should be some indication on the dash when regen in progress.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Our Signum puts out brown smoke when it regens and always seems to do it when i drive it.
    I will when I get chance get it removed and mapped out before it causes any trouble as the car is on 150k
    Nov 2009
    Warwickshire
    Barney, I have a 120 estate (140k). My last regen (after I noticed I had a split on the exhaust flexi pipe) started just before I pulled in a car park. After reading some great posting on the subject of regens that some members have put up I decided to pull over into a empty corner of the car park and sat with the revs at 3000. The car was engulfed in blue smoke and the readout was showing 1.7 galls. After seven minutes it completed and calm returned the fog cleared and like you I just let it run on tickover for a few minutes with consumption showing the normal 0.1 galls. Normally I get a regen when I'm on the move and only notice the delicate swirl of smoke in the rear view mirror. A stationary regen is quite an experience - hard to believe it's to cut down on pollution.
    PRESTON
    Quite an experience is about right Journeyman. I can relate to the phrase engulfed in blue smoke. Most of my regens have been on the move and hardly noticeable so it must be due to static regen, never again, next time i will take her for a drive. Ty for your post.
    Mar 2012
    alton
    Dont want to sound doppie but what's a regen??
    PRESTON
    It's what cars fitted with diesel particulate filters do when they burn off the soot that's collected in the filter. Mostly fitted to diesel Veccy estates, Signum and cars fitted with auto trans.
  1. regen
    By marko1966 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th September 2012, 07:36
  2. DPF Regen
    By Andyc6845 in forum Engine & Drivetrain
    Last Post: 16th February 2011, 21:15
  3. DPF & Regen??? WTF!
    By Rab in forum Diesel Engine related
    Last Post: 28th September 2010, 13:05
  4. DPF Regen
    By Avenged in forum Engine & Drivetrain
    Last Post: 20th May 2009, 17:44
  5. DPF Regen
    By keith_johnson1967 in forum Engine & Drivetrain
    Last Post: 28th November 2008, 10:29
