Thread: Thermostat Replacement
    Regular Member dexter69's Avatar
    Apr 2012
    Stirling
    Default Thermostat Replacement
    I'm new to vx, and have noticed that the temp gauge doesnt move whilst I'm on motorway driving between Stirling and Glasgow, however, when in traffic, it'll move and fall between 90 and 0, never going over the 90 mark...
    Presumably this is the common thermostat problem, and as such, I wondered if anyone can point me in the direction of somewhere to get it fixed (and for not a lot of money !) ?
    Thanks in advance
    Dec 2011
    Seaham
    Do it yourself!
    Apr 2012
    Stirling
    Quote Originally Posted by Ben50n View Post
    Do it yourself!
    I'm about as technically minded as a dead sparrow.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by dexter69 View Post
    1.9 CDTI by any chance?
    WHere are you located?
    Nov 2010
    East Midlands
    Trim : design
    Thanks in advance
    Big help if you tell us what model, year and engine.
    Apr 2012
    Stirling
    Quote Originally Posted by AntSSSS View Post
    Even easier - 1.8 vvt
    stirling/glasgow....
    Feb 2011
    Selby
    There's a HOWTO on changing the 1.8 thermostat. I did mine a few months ago - it really is a very easy job: Undo bottom radiator hose clip, pull hose off, drain coolant into a washing up bowl. Undo clips on the hoses on the thermostat housing and pull the hoses off. Unclip the wiring plug from the thermostat housing. Undo the bolts holding the thermostat housing onto the engine block. Remove housing and discard. Clean area on block where housing goes. Get shiny new housing (complete with thermostat and sensor) and it's seal out of the GM box. Put seal in groove. Put new housing on engine block and refit bolts. Reattach sensor wiring and hoses. Refit hose clips. Refit bottom radiator hose and clip. Mix up coolant and water (50/50) and pour into filler until at the MIN level. Start engine. Run up to temperature checking for leaks. Rev to 3000rpm for a few seconds - you should see bubbles in the coolant tank. Top up if it goes below the MIN level. Switch off and allow to cool. Top up coolant again if needed. Job done
    Regular Member *enery*'s Avatar
    Mar 2007
    glasgow
    my friends garage..only guy i use and hes a vauxhall nut,
    mvr scotland
    3carron place
    kelvin industrial estate
    east kilbride
    g75oyl
    01355 237733
    07719567042
    Regular Member JaceyBoy's Avatar
    Apr 2012
    Bournemouth
    I just did mine, its very easy but you will lose all your coolant/anti freeze, so make sure you buy some first ready to top it up, also my car (2.2i) is the same, in fact runs cooler now I have changed it, runs around 80-85oc, I dont think they are supposed to run at 90oc (in the middle)
  1. Thermostat Replacement - Any Tips?
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2014, 23:30
  2. 1.9cdti 150 thermostat replacement
    By scotstrucker in forum Engine & Drivetrain
    Last Post: 5th June 2012, 20:01
  3. Thermostat replacement
    By ChrisB in forum Engine & Drivetrain
    Last Post: 21st November 2011, 13:40
  4. thermostat replacement
    By duncmill in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2010, 21:25
  5. vectra 1.9 120 thermostat replacement
    By tom_nw in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd December 2010, 14:41
