Results 1 to 2 of 2
Thread: Suspension spring pan rubbing on inner arch
    Aug 2011
    Warwickshire
    Default Suspension spring pan rubbing on inner arch
    Hi I was wondering if anyone could help, I've had my 1.9CDTI SXI about 18 months now and apart from an alternator had no problems. Then today on the way home I noticed a twanging noise like plastic flicking over metal when going over rough road with lock on. Investigated further to find the right hand front spring pan rubbing on the inner arch when on full right lock can upload photos tomorrow. The left hand side when on full lock still has 10mm clearance. Can't understand why this is happening, checked all suspension bushes and ride heights there all fine. Thought maybe the spring is going but jacked it up and the springs seem quite new. Can't understand the difference unless spring has gone before and damaged the spring pan. Any ideas?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    possible bent strut...
  1. Suspension Rubbing
    By mcpitman in forum Suspension, Wheels & Brakes
    Last Post: 11th December 2011, 12:00
  2. Nearside Rear Tyre rubbing against Arch liner / Exhaust.
    By mickydoos in forum Suspension, Wheels & Brakes
    Last Post: 18th July 2011, 18:37
  3. suspension spring again
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2010, 22:05
  4. noise from the front, tire rubbing suspension?
    By Adamdavi3s in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2008, 11:15
