Results 1 to 10 of 17
Thread: Slight idle stutter - 1.8 LS
    Dec 2011
    Nottingham
    Default Slight idle stutter - 1.8 LS
    Changed the spark plugs and cleaned out the throttle body, and now when the car idles, the revs drop ever so slightly and judder the car every two ish seconds. Could this be due to re fitting the throttle body without a new gasket, or wouldn't that effect it?
    Regular Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Did it do this before you did the throttle body?
    Dec 2011
    Nottingham
    No it was perfect before
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Possibly then. Did the gasket come off all in one piece? Has you checked all the pipes are back on properly?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    i have feeling you cannot get the gasket from VX, not sure where I came across that info tho
    Dec 2011
    Nottingham
    I didn't take the gasket off at all, just left it on. Merikiito, did yours idle fine before the plug change? I'm guessing it could be that! The new plugs I have differ from the old as they only have two prong things whereas the old had four.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The fault on the Zafira just sorted of happened. I have not got round to changing the plugs yet and currrently think the plug I cannot get out is faulty. i will change the plugs once I get them all out. Otherwise I think the coil pack has broken down but I am trying to find one I can swap with to try it
    Dec 2011
    Nottingham
    I'll re check all of the connections and attempt to get a gasket from somewhere. All of this is in an attempt to get the fuel economy somewhere around where it actually should be, getting 20-25 mpg at the moment!
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by blee93 View Post
    Ouch!!!! thats really poor. Temperature ok?
  1. Slight misfire at idle
    By Lozza in forum Vectra C / Signum Troubleshooting
    Last Post: 17th June 2011, 06:52
  2. Occasional engine noise, slight rough idle, poor MPG
    By Snizzers in forum Engine & Drivetrain
    Last Post: 16th June 2010, 10:44
  3. slight hicup/stutter when on motorway
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd May 2010, 22:31
  4. 2.2DTi idle stutter
    By si_hoss in forum Engine & Drivetrain
    Last Post: 19th July 2009, 15:07
  5. Slight engine stutter
    By frazejax in forum Engine & Drivetrain
    Last Post: 25th August 2008, 17:07
