Results 1 to 3 of 3
Thread: Fitting a Swirl flap actuator
    Sep 2010
    Plymouth
    Engine : 1.9 CDTi 150
    Year : 06
    Mileage : 250,000
    Default Fitting a Swirl flap actuator
    My 06 CDTi recently had a new manifold, at the time the old swirl flap actuator worked and so it was refitted.....
    However it has now give up the ghost, and i have a new one to go on the manifold, but i dont want to take the manifold off if i can get away with it.
    Can the actuator be fitted without removing the manifold? I will be removing the EGR for cleaning and i am lead to believe that will make access easier.
    Also what tools will be required for the removal of the actuator (torx, hex)
    Thanks in advance
    West
    Although i haven't done this myself... i'm told it is possible to just swap the actuator from underneath... although if it was me personally, i would leave the old one in place & only connect the new one electronically IE by the connecting plug & tie wrap it somewhere safe, that way the flaps stay open & do not operate but the actuator fools the ecu to thinking all is as it should be, even the new modified manifolds are failing & IMO your better off running without it full stop.
    Just to add... i looked deeply into the swirl valve system & opted to bond mine open rather than replace the manifold, I will not be replacing my manifold any time soon as it's much better without the swirl flap operation & if i did decide to change the manifold i would either opt for modifying my own or purchasing an older alfa part no without the swirl pots... hth
    May 2006
    scotland
    I completely agree with dh above. One thing I have not managed to find yet is where the electrical connector is for the swirl valve actuator (in case mine ever gives up the ghost and all I would do is buy a new actuator, and electrically connect it to fool the ECU and then would glue swirl pot 3 open)?
  1. Swirl Flap kit fitting
    By Casper85 in forum Engine & Drivetrain
    Last Post: 7th September 2012, 16:31
  2. Intake Air Flap Actuator
    By rickylennan in forum Vectra C / Signum Troubleshooting
    Last Post: 6th January 2012, 21:32
  3. Swirl flap actuator
    By jofenan in forum Engine & Drivetrain
    Last Post: 12th October 2011, 21:01
  4. Swirl Flap actuator
    By M20 RUM in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2010, 21:51
  5. swirl flap actuator?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2010, 15:47
