Results 1 to 10 of 14
Thread: coolant leak
    Feb 2012
    County Armagh
    Default coolant leak
    hi there, i have had code 3 come up on me twice within two days on my insignia, i have filled up both times and with 10 mile code 3 appears again, i opened bonnet tonight and i noticed water lying on engine cover and a few drips coming from right had side of engine between engine and battery compartment about the same level as the turbo, i think this is the egr cooler, do i need to replace or can i fix it, much appreciate your help cheers David
    Dec 2011
    Seaham
    Is the car under warranty?
    Feb 2012
    County Armagh
    i am the second owner from new and i dont think the person i bought it of gave me warranty
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    EGR cooler is a known issue on this car, they recently had to do someone elses..
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Depending on how old the car is and the mileage you might still have a VX warranty
    Whats the year and month of manufacture?
    Whats the mileage?
    I also have a feeling the coolant leak is a known fault, maybe someone can confirm that via TIS?
    Also a few other things would help such as which engine do you have?
    Feb 2012
    County Armagh
    so can i replace gasket or something or does the whole part need replaced, i have the 2.0 cdti engine 160bhp, it is 2009 with 32000, exclusiv model, i am the 2nd owner does that matter, thanks for your help
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by DavyB View Post
    Can you answer the other questions and then someone might be able to tell you
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by plasma View Post
    It was mine mate Its a known fault with the crappy design of the plastic housing for EGR cooler, There is no way to fix it except replace part and your looking at near £800 to replace it as part is well over £400
    check my thread http://www.vectra-c.com/forum/showth...52-Broken-down
    Irmscher Insignia CDTI 130
    Northampton
    Engine : A20DTH
    Mileage : 88000
    i think you have 3 years and 60k which ever is sooner so you might still have warranty left, what month?
    And yes even if you are the second owner you still will have VX warranty as it transfers to the new owner automatically
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by merikiito View Post
    +1 but even if its just outside warranty i would argue the case and get vauxhall to help with repair costs
  1. Coolant Leak
    By Sike in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2012, 13:52
  2. Coolant leak
    By Vin in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 22:49
  3. Coolant leak
    By mzctc7 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2010, 11:26
  4. Coolant Leak
    By trickydickySRI in forum Vectra C / Signum Troubleshooting
    Last Post: 20th April 2009, 09:25
  5. Coolant Leak???
    By ChrisFox in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2009, 05:46
