Results 1 to 3 of 3
Thread: Snowflakes have lost me MPH
    Regular Member Mopar Man's Avatar
    herts
    Default Snowflakes have lost me MPH
    Since going from 17" to 19" snowflakes, i have noticed my speedo has dropped about 5 to 10 MPH doing high speeds. Is there different speedo gearing and is it easy to do. Thanks Alan
    Regular Member MattVecVXR's Avatar
    Mar 2012
    Torpoint, Cornwall
    Trim : VXR
    Engine : 2.8 V6 Turbo (280)
    Mileage : 82000
    As long as the outside diameter of the tyres/wheels are the same it should be unaffected. I've put 19s on from 17s before and it remained the same because the 19s had lower profile tyres on.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The tyre size can be changed in the ECU using pc software or tech2.
    What I did with mine was stick the cruise control on 70mph and check the reading given by Tomtom/satnav then adjusted the tyres in the ECU until I got the correct reading on the speedo, you can also specifiy your own diameter.
  1. Lost MPG
    By benwalters82 in forum Engine & Drivetrain
    Last Post: 12th February 2012, 18:10
  2. lost.....do i need new ecu?
    By lilangel in forum Vectra C / Signum Troubleshooting
    Last Post: 21st May 2011, 20:35
  3. lost 4 box set
    By xrken in forum General items for sale
    Last Post: 13th May 2009, 22:05
