Thread: Fault codes
    Regular Member GSi-Col's Avatar
    Aug 2009
    Kirkcaldy, Fife
    Default Fault codes
    Got the current fault codes at the moment
    Total number of fault codes: 4
    P0300 - Random/Multiple Cylinder Misfire Detected
    (01) - Not present
    P0302 - Cylinder 2 Misfire Detected
    (01) - Not present
    P0313 - Misfire Detected at Low Fuel Level
    (08) - Present
    P1614 - <Unknown DTC>
    (50) - Not present
    Anybody shed any light on what i need to look at to try and fix?
    Feb 2011
    Selby
    Start by clearing the faults and seeing if they come back. Misfire reports (IIRC) stay recorded, even if the misfiring has stopped. So given there's a 'misfire detected at low fuel', that would imply that it's run out of fuel at some point and misfired as a result.
    I got a misfire on cylinder 4 recorded when the thermostat had failed and I was running on LPG and trying to accelerate too hard straight after starting when it was -10C outside. Once I replaced the thermostat it's been fine ever since.
    South east
    Going by your User name, I'm assuming this is for a 3.2 V6? The most likely cause is a faulty coil pack which is affecting cylinder 2. You could be lucky and find it's just the spark plug in that cylinder that is at fault.
    Aug 2009
    Kirkcaldy, Fife
    Cheers guys and Rebellion yeah for 3.2
    Aug 2009
    Kirkcaldy, Fife
    Well had the spark plugs replaced this week and been running fine since then
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
