Thread: Clutch Problem
    May 2011
    Leeds
    Default Clutch Problem
    Morning Guys,
    I think my clutch maybe on its way out. Itís on a 2.0T on a 53 with 85000 on the clock.
    Is it a case of replacing the clutch or should I be getting other things done at the same time.
    Any ideas on price for this job.
    Phil.
    South east
    Firstly, what are the symptoms? If the clutch is indeed worn, the have the dual mass flywheel replaced at the same time.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    As an idea on price looking at around 7 hours labour.
    May 2011
    Leeds
    Quote Originally Posted by Rebellion View Post
    Only reason i think it's on its way is the peddle suddenly seems to have a very high bite point, apart from this the car runs as well as it ever has.
    I thought only diesels had a DMF?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by philc1210 View Post
    Bleed the clutch (and brakes) through with fresh fluid at all points. Can help
    Regular Member sscully's Avatar
    Jul 2011
    WALLASEY
    Vehicle : Vectra C Facelift
    Trim : SRI
    Engine : 1.9 Diesel
    Mileage : 89000
    I had a rover 75 petrol and that had a dmf. I now have the vectra sri diesel and I had my clutch, flywheel and slave replaced. cost 680 with 12months warranty
    Jul 2011
    WALLASEY
    Trim : SRI
    Engine : 1.9 Diesel
    Mileage : 89000
    Wrong post
  1. clutch problem please help
    By v33tra in forum Engine & Drivetrain
    Last Post: 12th November 2011, 02:09
  2. Clutch problem!
    By kel123 in forum Engine & Drivetrain
    Last Post: 5th October 2011, 16:07
  3. Clutch Problem
    By ickleric in forum Engine & Drivetrain
    Last Post: 31st January 2011, 19:19
  4. clutch problem?
    By darko2301 in forum Engine & Drivetrain
    Last Post: 10th April 2009, 21:33
  5. Clutch Problem
    By Aimee in forum Engine & Drivetrain
    Last Post: 30th August 2006, 23:31
