Thread: Display
    Sep 2011
    Kent
    Default Display
    Hi can a display gid etc be taken out of fafelift vents and put in preface lift vents ?
    Which display came as standard in a cd40 ?
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    GID is standard with the CDC40 not sure about the swap but I don't see why not but I'm sure someone will correct me if I'm wrong.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I think that only the Facelift CID cannot be fitted to a pre-facelift display surround.
    Facelift CID's are "wide-screen" format...
    ALL other displays are not, however do note that with some minor modification, you can get a facelift vent surround to fit a pre-facelift unit.
    I did this for the wife's 2005 Vectra, when I fitted a 2006 CD70 and CID.
    The GID is indeed the standard display for the CDC40 (Opera) with and without DAB.
    Sep 2011
    Kent
    brill guys, Robsey how do you get it to fit ?
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Basicly, I ground the top 3 or 4 mm (approx 1/8") from the top of the surround.
    The facelift surround is rounded along the top edge.
    I ground hers flat along the top. Do note though that the rounded corners will still be there.
    I then pushed the display up whilst screwing the 4 self-tappers back into place
    If you don't do this, then the trim strip (that runs from above the glove box, and goes under the vent surround), will not fit in under the vent surround.
    Here is an image from e-bay, which I have modified to shows where to grind the top surface flat.
    Sep 2011
    Kent
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Ahh, well, not all of them. I had an FL 06 Exclusiv 1.9CDTi (Reg No started FL06 too!!) and paid £400 extra for a factory fitted upgrade to a CDC40, but this came with a TID.
    Miserable sods at Vauxhall.
    In fact I never had a GID display until I retro-fitted one in my own 53 plate 2.0DTi, bought with my own money, the Vectra's before that one were all company cars.
  1. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  2. mp3 on display
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 27th August 2011, 14:54
  3. PS3 display
    By @ndy-e in forum Games Room
    Last Post: 27th December 2010, 08:21
  4. temp display on radio display
    By MRunMotorsport in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2010, 15:55
  5. LED DIsplay
    By dcraigen in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2008, 10:16
