Results 1 to 3 of 3
Thread: spanner light on for first few minutes
    Aug 2010
    south northamptonshire
    confused spanner light on for first few minutes
    hi guys,
    having just fitted a lift pump on my vectra 2006 1.9cdti 150 it now starts but iam getting a spanner light comming on the dash for a few minutes it then disapears, i have tried reading fault memory even when the light is on and there is no faults in the system ive tried 3code readers to check its not the reader. i have monitored the MAP sensor and it is reading 95kpa when engine is off and when at tickover however when foot fairly hard down rises to 242kpa. does anyone have any ideas of what the fault could be is the map sensor suppose to read same at tick over and even when engine is not started.
    cheers
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Your probably find that you have a glow plug failing try heating the glow plugs up a few times before starting the engine
    Aug 2010
    ok cheers bud will try that i only changed them 6months ago
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Battery light on 5 minutes after starting
    By SlowCoach in forum Vectra C / Signum Troubleshooting
    Last Post: 4th December 2012, 10:24
  4. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  5. Battery Light comes on after 3 minutes of Driving
    By bren in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2008, 18:08
