Results 1 to 10 of 13
Thread: Oil leak on my 2.0 T, not sump plug, any ideas??
    Regular Member Steve 100's Avatar
    Apr 2012
    Grimsby, Lincs
    Default Oil leak on my 2.0 T, not sump plug, any ideas??
    Got an annoying, but slow oil leak on my 2.0T. I've had a look underneath but can't find where it is coming from. The sump plug is fine and dry. It seems to be coming from the left side of the engine. Anyone else had this?Thanks in advance for any help!
    South east
    "Left side" when you're facing which direction?
    Apr 2012
    Grimsby, Lincs
    Passenger side of car.
    Regular Member gibbon7000's Avatar
    lincs
    Have you checked the pipes from the turbo?
    South east
    Or the seal between the gearbox and the engine.
    Apr 2012
    Grimsby, Lincs
    Quote Originally Posted by gibbon7000 View Post
    I'll have a look.
    Quote Originally Posted by Rebellion View Post
    Is that a big expensive job to change if it is leaking?
    Apr 2012
    Grimsby, Lincs
    Had a look underneath and it looks like it might be the oil seal on the drive shaft!!
    Apr 2012
    Doncaster
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : Z30dt
    Mileage : 104000
    Just done same job on my signum. Amazed at how easy it was seals r 8 pound odd from vauxhall. Handy to change gearbox fluid at same time.
    Apr 2012
    Grimsby, Lincs
    So how did you do it and how long did it take?
    Apr 2012
    Doncaster
    Trim : Sri
    Engine : Z30dt
    Mileage : 104000
    At a guess id say hour and half taking it easy. Jack car up, wheel off loosen cv nut leave nut on threads so you have a nice face to hit with a soft face hammer to release it from splines. Give it a wack so its loose couple will do. Then undo mountings for bottom arm swing out of way while moving driveshaft and cv boot out of the hub. Remove driveshaft from gearbox, can be stiff but keep trying it will come.
    Once removed u will see the seal to replace just use a screwdriver to release seal. The n pop new one in being careful not to damage it. Tap it home flush then install everything in reverse. Fluid will escape from gearbox so just do a full oil change while uour at it. Job done
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. One sump plug or two on a VVT.
    By disco dan in forum Engine & Drivetrain
    Last Post: 12th October 2011, 18:36
  3. Slight oil leak from sump plug.
    By AlexGSi2000 in forum Engine & Drivetrain
    Last Post: 11th July 2011, 22:28
  4. Rounded off sump plug... any ideas?
    By BigWilko in forum The 'Off Topic' room
    Last Post: 20th July 2010, 22:10
  5. Sump Plug Nut
    By si_hoss in forum Engine & Drivetrain
    Last Post: 22nd February 2010, 18:32
https:www.vectra-c.comforumshowthread.php164224-Oil-leak-on-my-2-0-T-not-sump-plug-any-ideas
