Thread: Engine cover rattle and engine cough
    Default Engine cover rattle and engine cough
    I have an 08 Vectra Est 1.9cdti 120. The engine cover is ratteling and have been quoted £24 for the rubber grommets. Any other ideas.
    Also I wa driving home the engine temp was at 90, i put it in to second and there was what i can only describe as a cough, wher the engine missed a beat and the carried on. When I got to the lights it sounded like the engine was pulsing.
    Kind Regards
    PRESTON
    I see from your profile that you have an estate car, could be it was performing a regen, did your instant consupmtion go through the roof too?
    Those grommets are expensive and as far as i know can only be got from the dealers, they come with new brass ferrules too. Anybody found a work around for these yet?
    I didn't notice the fuel consumption.
    Would just undoing the screws at the fron of the engine cover and putting a couple of large washers do the trick for the rattle?
    Regular Member LJ sxi-nav's Avatar
    Winchester
    I've had the engine cover off my 120 for months now, as it wore away the holes so they were larger than the size of the grommets! I did have a temp repair using washers stuck to the underside of the engine cover and this worked well until I next took the cover off and lost the washers!... haven't got round to replacing yet, but at least there is no rattle!
  1. VVT Engine Rattle.
    By VVT-i-MATT in forum Engine & Drivetrain
    Last Post: 27th November 2013, 18:24
  2. Engine Cough / Hesitation
    By Hursty103 in forum Engine & Drivetrain
    Last Post: 30th July 2012, 12:03
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Engine rattle
    By wee-willy-winky in forum Engine & Drivetrain
    Last Post: 27th March 2012, 20:39
  5. engine rattle
    By TONY.N.F.F.C.ROSE in forum Engine & Drivetrain
    Last Post: 18th March 2010, 14:54
vauxhall engine cover rattling
vectra c 1.9 engine cover rattling
