Results 1 to 2 of 2
Thread: Vectra break light and indicator issue
    Mar 2007
    S Wales
    Default Vectra break light and indicator issue
    Ok so I have vectra Sri 1.9cdti 2006 and I have two issues but they did start off at different times so I'm assuming at the moment they are not related.
    Issue 1. - rear right brake light - so I've replaced the bulb three times now as it lasts for few days and then blows. I've played with the connections but can't find and issues does anyone have any suggestions.
    Issue 2. - front right indicator - so when I indicate right I get rapid indication and the front indicator won't work but the others do. The left works fine. When the hazards are put on its normal speed and the front right indicator still won't work. Iv changed the bulb but it's still not fixed it. Iv not had much time to investigate but has anyone any suggestions?
    Anyone know where I can find a wiring diagram so I can trace back the wiring and look for dodgy connections or wiring?
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    issue 1. I would clean the metal contact that is at the bottom of the bulb holder and make sure it is deffo making good contact with the bulb. Scrape the soldered bit at the bottom of the bulb before fitting it. Change the brand of bulb and make sure it is a 12V one.
    issue 2. the normal indicator will flash faster with a bulb not working, the hazards wont. in the dark, with the RHS indcators on, check the front and rear lights for any bulb that is coming on dimly. If so, this will probably be an earth fault with the front indicator.
  1. very weird issue with indicator
    By gregj in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2013, 19:05
  2. Bizarre indicator issue
    By Chip in forum Electrical & ICE (including SatNav)
    Last Post: 23rd August 2012, 16:40
  3. Indicator issue.
    By ElSpoooel in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2010, 18:53
  4. Front OS indicator issue
    By CowFish in forum Electrical & ICE (including SatNav)
    Last Post: 28th October 2009, 08:43
  5. ABS Break Light!!!! ON & OFF.
    By Sendall5 in forum Suspension, Wheels & Brakes
    Last Post: 17th February 2009, 19:24
