Thread: Vectra c 19cdti 54. Intermitten splutter
    Feb 2012
    Wolverhampton
    Default Vectra c 19cdti 54. Intermitten splutter
    I've recently started having a problem
    when I'm driving along
    it doesn't matter what speed
    my car will sort of like die for a second or two
    and then it's ok
    it doesn't happen every time i'm out in it
    its really annoying when it does
    any ideas of what it could be please, many thanks bill
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Throttle position sensor it sounds like to me. Check out the how2 to check/remedy this:
    http://www.vectra-c.com/forum/showth...45#post1338145
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Is it the 150 0r 120 version?
    If it is the 150 similiar problems are caused by the 3rd injector plug (yellow) and the fact it needs upgrading to the blue plug
    see this how 2: http://www.vectra-c.com/forum/showth...njector-wiring
    Feb 2012
    Wolverhampton
    Thanks I'll give them both a try over the next couple of days
    many thanks,bill
    Feb 2012
    Wolverhampton
    I've done the third injector
    Cleaned the egr valve
    The turbo sensor
    Put new vacuum pipes on
    Re-sat all the injectors
    All I need to try now is the throttle position sensor
    If it's not that
    Then any other ideas of what it could be pls
    Many thanks again Bill
    Regular Member dalekirkwood's Avatar
    Feb 2012
    Cambridge
    Inlet Manifold?
  1. vectra 19cdti (150) intercooler hose's mod????
    By mark the hat in forum Diesel Engine related
    Last Post: 10th October 2011, 21:51
  2. 2007 vectra 19cdti £5200 NOW £4800
    By dave16v in forum Cars for sale
    Last Post: 8th January 2009, 23:25
  3. 2007 vectra 19cdti £5200
    Last Post: 6th January 2009, 20:23
  4. Vectra 1.9 CDTI 150 2005, Intermitten Problem
    By Vaux-Man-G in forum Vectra C / Signum Troubleshooting
    Last Post: 24th April 2008, 11:53
