Thread: thick black smoke cdti.
    hull
    Default thick black smoke cdti.
    hi all, as title my car (cdti120) kicks out thick black smoke when i boot it, more than is normal i think. What should i be looking at to cure the problem or is this normal?? Seems to be worse in second gear.
    Only had the car for two months but the diesel fumes smell quite strong aswell, much more so than the picasso hdi i had, is this normal?
    thanks.
    Sodding Typical on Sea
    What mileage has the car done? when was the last oil change? what type of oil, semi or fully synth? and how does the car generally drive? Is this a new symptom or has it always been a smoker since bought?
    A few questions to start to narrow down the thinking,,,
    hull
    Quote Originally Posted by Derek Mc View Post
    mileage 106k, oil/filter/fuel filter/cambelt kit changed at 101k 3 months ago. semi synth vaux oil 10w 40. car drives spot on with plenty of grunt.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    I think i'm right in saying that all the facelift diesels have a dpf, so there shouldn't be much, if any smoke. Do the fumes smell in the cab or just from the exhaust?
    hull
    Quote Originally Posted by BigWilko View Post
    hi, no dpf on mine i believe, checked the code on the door plate as mentioned in another thread. No fumes in the cabin, just seems strong outside the car.
    Oct 2010
    London
    Check the boost sensor, intercooler pipes from turbo to manifold and check air filter as well.
    Boost sensor is likely to be gunged up with crap so the engine is over-fuelling! Other sensors to check are the MAF which I think is attached to the airbox?
    West
    It's deffo over fuelling, check all the pipework & intercooler for any tell tale signs of a split
    hull
    thanks guys, thought it might be over fueling as mpg isn't so good as i thought it might be. (42average on bc) and thats with a light foot.
    Where can i locate the boost sensor cdti 120??
    Oct 2010
    London
    Take plastic cover off engine, remove the insulation, then look for the inlet manifold (on the back of the engine) and you should find a sensor in the middle of the manifold, reasonably big with an oval plug on it, secured to the manifold with a bolt. If you find it, remove it and if it is gunged up blast it with carb cleaner.
    I think there is a how to guide on the forum somewhere with pictures, have a look!
    hull
    Quote Originally Posted by Homer View Post
    cheers for the info mate..
  1. Poor Starting & Thick White Smoke (2.0DTI)
    By Daniel89 in forum Engine & Drivetrain
    Last Post: 4th June 2012, 13:47
  2. exhust thick black smoke
    By faizyan6000 in forum Troubleshooting
    Last Post: 29th February 2012, 14:22
  3. Help a sick V6CDTI - Thick white smoke
    By Celes in forum Engine & Drivetrain
    Last Post: 28th August 2010, 21:02
  4. 1.9 cdti (150) Black smoke
    By ste_goffy in forum Engine & Drivetrain
    Last Post: 18th July 2009, 16:37
  5. Whoosh and thick grey smoke!!!
    By ChrisFox in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2008, 00:38
