Thread: Random Judder - 1.9cdti
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    Default Random Judder - 1.9cdti
    Just been cruising down the M1 (well up) at the speed limit 70mph..... in the fast lane and i had a completely random judder from the engine.
    I had no warning, Nothing after, just 3 strong judders, as if the car was going to stall.
    Had just filled up with fuel 80 miles ago. No high temps, EGR is disabled/blanked via remap, No lights came on on the dash, radio didn't even go off or anything like that. I dropped to 5th gear immediately and accelerated (there was a car approaching my ass) and everything was fine. Pulled like a train as you would expect.
    Any one had anything similar? Or suggestions?
    Im hoping its a 1 off. Maybe some poop in the fuel or something like that. (I only fill up at local shell)
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I would check the what colour the 3rd injector plug is, if its yellow it needs changing to the blue uprated version.
    The dodgy injector plug can cause the issue you had and eventually will break down further and cause even more issues. It started the same way with mine
    Feb 2012
    Sheffield
    Its Blue. I checked that one when i got the car.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    How long ago was the fuel fitler changed?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Id be changing the fuel filter too straight away.
    Also check your other injector plugs.. Give them a spray with contact cleaner (NOT WD40) and cable tie them tight to the injector...
    Feb 2012
    Sheffield
    fuel filter has done about 900 miles since change All filters are under 1k miles old lol Well looked after my car luckily!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Might have to see if it happens again then
  1. random
    By nicj in forum Comedy & Humour
    Last Post: 23rd January 2013, 13:11
  2. Random
    By signum_rob in forum The 'Off Topic' room
    Last Post: 14th January 2013, 20:13
  3. Random giggles
    Last Post: 16th December 2011, 14:25
  4. 1.9cdti judder and loss of power then fine.
    By voxvectra7 in forum Engine & Drivetrain
    Last Post: 27th September 2011, 23:42
  5. A bit of a random one!!!
    By adamtaylor in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2009, 09:19
